Old November 19th, 2017, 18:34
naxjxj naxjxj is offline
Best Steering/Suspension maint."Bang-for-buck"? (Stock)
2WD XJ '95 110k
Doesn't desperately need anything - but steering is kinda sloppy, just general wear - nothing big.
(minor death-wobble at 60+ isn't big deal).
TOTALLY STOCK 2WD -and going to stay that way. It's great !
What's been your best "bang for the buck" item changed ? (not just in $$ terms, but also ease-of-labor)
2 things I'm planning on :
- Sway-Bay Bushings ($10-15)
- Steering Shock-Damper ($35)
Which of additional following would have greatest impact ? :
- Tie-Rod ends
- Upper Ball-Joints
- Lower Ball-Joints
- Drag-link Sleeve
- Sway-Bar Links
Old November 19th, 2017, 20:12
trippled trippled is offline
Re: Best Steering/Suspension maint."Bang-for-buck"? (Stock)
Changing random parts will really get you no where. Have someone turn the steering wheel back and forth with the car on the ground while you check everything for play. Track bar is a common failure and if it's worn can have a huge impact on the front end.
Old November 19th, 2017, 20:27
When you say "Trackbar failure" - you must mean the ends/connecting points, not the bar itself :
the Ball Stud end ?
or the Bolted end ?
(unfortunately, it'd be weeks before I could get anyone to help - and wanted to work on this next week, when I finally have some days off. So I'll have to make educated guess, based on general wear of an otherwise good vehicle)
Old November 19th, 2017, 20:51
Yes the stud end. But seriously,an educated guess is a fancy way of throwing parts at it. At a minimum jack up the front end and shake everything down, use a pry bar, etc.
Give a stranger a beer for 60 sec of shaking a steering wheel!
Old November 20th, 2017, 13:18
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
As part of your maint./ upgrade, get the V8 ZJ tie rod/ ends.
Also with this, you need to do a tape measure toe alignment. Unless you plan to take it to a shop.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old November 20th, 2017, 15:40
md21722 md21722 is offline
Sloppiness can also be the steering box itself.
Old November 22nd, 2017, 20:47
alexgalexg's Avatar
alexgalexg alexgalexg is offline
Totally stock Jeeps are the coolest. First off that stabilizer for the steering. Its cheap and will eventually start to moan... swap it.
Steering brace:
The one that comes on it is crap. You likely have slop because its broken and tearing your unibody. Buy a big brace for the steering gear box and you should be set.
Shocks and leafs:
Change those and this baby will handle better than all the crap excuses for 4x4's 2017 has to offer.
If you still have problems after that naxja is always here to help but providing you have good tires under you it definitely wont be costly
tell me your opinion best bang for your buck on steering upgrade jcshaney Midwest Chapter 29 August 25th, 2014 16:55
best bang for the buck Jeemy B. Modified Tech Discussion 15 September 25th, 2009 23:05
best bang for buck-97 tahoe bcmaxx Tow Rigs and Trailers 0 April 29th, 2008 22:05
Best bang for the buck JohnJohn Jeep Street and Performance 12 January 26th, 2005 07:14
best bang for buck 90xjDave Non-Tech / Off Topic 0 August 20th, 2003 11:43
