Old November 19th, 2017, 17:17
90xj06's Avatar
90xj06 90xj06 is offline
lights pulsing
I noticed this the other day. at least at idle my dash lights and interior lights pulse. the interior lights are led but the dash lights are still incandescent.
Alternator and battery are 1 year old. anything i should look at. i have added an additional battery to frame ground.
Old November 19th, 2017, 20:08
techno1154's Avatar
techno1154 techno1154 is offline
Re: lights pulsing
When my XJ did that the regulator was the culprit. What regulator are you using?
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old November 20th, 2017, 06:11
90xj06's Avatar
Re: lights pulsing
i believe it is in the alternator. i forgot to list it is a 1988 with the 4.0
Old November 20th, 2017, 06:34
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: lights pulsing
ever done this?
http://cruiser54.com/?p=110
Old November 20th, 2017, 09:35
techno1154's Avatar
Re: lights pulsing
Actually, the regulator is in the PCM.
My XJ did that because I disconnected the PCM regulator from the alternator and installed an external regulator which was adjustable in an attempt to increase the charging voltage up to 14+ volts. I have since reverted to the PCM based regulator.
Originally Posted by cruiser54 View Post
Doing this is a good idea.
Patrick
#594
Old November 22nd, 2017, 10:12
JeepNoob JeepNoob is offline
Re: lights pulsing
If you've got a multimeter that does it, check for AC voltage (NOT DC!!!) between the alternator output wire and a good ground such as the alternator case with the engine running. Any AC voltage coming and going from the alternator probably indicates that a diode in the alternator has gone bad.
Pulsing idle Kiefer316 OEM Tech Discussion 6 February 18th, 2010 10:14
ABS not pulsing brakes mikeprince OEM Tech Discussion 2 February 12th, 2009 10:23
Brake pulsing BUT... Rocketman OEM Tech Discussion 2 September 16th, 2006 19:35
Pulsing at 60 mph a_tittman OEM Tech Discussion 0 October 13th, 2005 14:48
Pulsing Accelleration? Skorpyo OEM Tech Discussion 0 July 17th, 2003 05:10
