Old November 19th, 2017, 13:18
nick94country nick94country is offline
Rear main bearing cap
Does anyone know were I can find a new rear main bearing cap? 1994 xj country 4.0
Old November 20th, 2017, 16:52
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Rear main bearing cap
Find a used cap.
The block will need its main bearings line bored, with the “new” cap.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Main bearing and oil pan questions SBpunk OEM Tech Discussion 6 June 25th, 2014 11:08
'89 Rear main bearing seal issue Brandon77 OEM Tech Discussion 11 August 5th, 2012 16:37
258 rear main bearing cap bolts gtpolkus Non-Tech / Off Topic 4 July 30th, 2006 13:28
Rear Main Seal/Bearing Cap problem JnJ OEM Tech Discussion 6 April 3rd, 2006 11:40
Rear main bearing cap torque? (lost manual...) CameronB OEM Tech Discussion 2 August 25th, 2003 08:20
