Old November 18th, 2017, 15:23
aequitas12 aequitas12 is offline
Won't start after thermostat and water pump.
I just did a thermostat, water pump, and heater core flush on my 99 xj 4.0. After I top off levels I let it idle in the driveway to get up to temp and the heat is working great now. Ran fine for probably 10 minutes in the driveway and I took off down the road and made it about 500 ft and the engine died and won't start. Heat never went over 200. I saw a thread saying the temp sensor in the thermostat housing can cause it to flood so I put in a new sensor and still nothing.
Old November 18th, 2017, 16:24
md21722 md21722 is offline
Re: Won't start after thermostat and water pump.
Are you sure there isn't any air in the system? The temperature sensor does not do a good job reading air or steam. It should have taken about 8 quarts to fill, not including the coolant reservoir. When filling, you can use a high tech vacuum filler, remove the upper radiator hose at the thermostat housing, or try pulling it up on ramps or parking uphill. You can probably get it started again by flooring it while cranking.
Old November 18th, 2017, 16:47
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Where did all the water from the heater core flush land ?
I would guess that you might have a dampness problem causing a short in a wire connector, that got the distributor wet, or that the stall and no-start are simply random bad luck. You should start basic troubleshooting of the fuses, relays, and wire connections for a no-start. Then you might want to test the Crankshaft Position Sensor.
I would like to see this post about the Coolant Temperature Sensor causing a flooded engine, because that doesn't make any sense.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Water pump and thermostat housing bolts the_bandit87 OEM Tech Discussion 0 August 14th, 2005 14:40
Thermostat blows water pump gasket! Fink City OEM Tech Discussion 0 May 5th, 2005 22:20
Lock-Tite on Timing Chain Cover, Water Pump and Thermostat Housing? Johnny V OEM Tech Discussion 7 November 19th, 2004 23:22
Replacing my Water pump and thermostat, couple questions? HEX-J OEM Tech Discussion 14 August 27th, 2004 20:00
Water pump and Thermostat g2z24 OEM Tech Discussion 0 August 9th, 2003 19:14
