Old November 18th, 2017, 12:11
flazz85's Avatar
flazz85 flazz85 is offline
Brake lights stay on, modified LED harness, been working fine for years
First off just would like say hey all, it's been awhile.
Jeep info
1997 4.0L
AW4
Modified tail lights- LED set up using a tow ready harness (followed Hammered's write up) been working fine for about 3 years
Anyway the other day found out my brake lights are doing a steady burn (looks like I'm driving around with my brake pedal pressed). I switched out the brake light switch for a new mopar one and the brake lights still stay on, including the third in the middle. Other things I've noticed are the turn signals still work fine, brake lights go off when xj isn't keyed on, hazards work correctly, if I don't have it keyed "on" or running but turn on lights, the brakes lights operate correctly in running light fashion and if I press brakes in they operate correctly. If I turn key over brake lights immediately turn on with out lights being turned on and produce the steady burn as if brake pedal is pressed.
It seems I'm past the brake switch so I've been checking my fuses and such, all are good, I did also noticed the fan for my climate controls has been engaging immediately when I key on as well. The climate controls are on the same fuse and relay as the stop signals. My question would where should I start looking for the short? I started cleaning the grounds to see if that helps. Maybe a different module or relay went bad. If anyone thinks of a different test to try let me know.
Old November 18th, 2017, 13:40
flazz85's Avatar
Re: Brake lights stay on, modified LED harness, been working fine for years
Also, took off an old trailer wiring harness which helped the situation for a while but the problem returned, I'm at the point where I'm probably going to buy some new tow ready harnesses and re do the LED's and hopefully that is the cause of the problem
Old November 19th, 2017, 15:10
flazz85's Avatar
After i took off the old trailer harness, it worked for I'd say 15 minutes, what is the box under the driver side dash that the brake light switch plugs into? It's a white plastic box that seems to hold the majority of the lighting system wiring? Haven't had anyone help out with suggestions, hell at this point anything is welcome
Old November 20th, 2017, 08:22
Heavyopp Heavyopp is offline
Shorted with fuel pump? -- what else would run to the back thats keyed power?
Brake lights not working short_ones_xj OEM Tech Discussion 0 May 7th, 2017 12:25
Brake lights not working, third brake light works fine wolfman_023 OEM Tech Discussion 10 October 3rd, 2013 14:30
Brake Lights Not Working 2000 XJ stungun187 OEM Tech Discussion 3 December 21st, 2009 14:32
brake lights not working altierior OEM Tech Discussion 5 July 6th, 2007 17:03
Brake lights not working! FU-UR OEM Tech Discussion 6 November 4th, 2005 16:57
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
