Old November 17th, 2017, 20:48
98xjbeater2 98xjbeater2 is offline
wiring up LED's
i have a 98 xj. i put on LED's on my front bumper
i live in pa.
pa law says i can add the LED's, buy i can only use them w/ low beams.
And i read in a auto electrical book i have telling me to never run a wire for a added accessory, directly to the fuse box, cause it can melt.
(i already experienced it on a previous xj)
so can anyone give me a link or directions on how to find the correct color wire for my front parking lights?
i want to run my power (fused) wire for LED's to my parking light harness.
And i was going to add in the future: a overhead lightbar,, pillar lights, & at least one LED on back bumper
Plus i do have a winch, & i put a toggle switch on my stock electric fan,
+ a aftermarket horn
I put on a good top post battery from my dodge diesel, & a aftermarket more powerful alternator.
i was thinking of getting a 2nd battery, &/or a added 6 place fuse box.
i don't want a million wires going to my battery. I figured a 2nd battery will help.
so if anyone can offer links, drawings, advise, anything to help.
Plus how would i even wire up a 2nd battery?
Old November 18th, 2017, 07:25
EMSJEEP's Avatar
EMSJEEP EMSJEEP is offline
Re: wiring up LED's
You're going to run a wire direct to your main battery and either a) fuse it or b) buy an accessory fuse block so that you can jump one wire off of your battery and wire up multiple accessories now or in the future. I like this one:
http://shop.pkys.com/Blue-Sea-5026-S...SABEgIDkvD_BwE
Having a second battery is good. Buy a kit. You'll need to find a place for it and isolate it either via isolator or relay. You do NOT need a second battery to run a few LED lights, but its nice to have to self jump if needed. Not sure what alternator you put in, but it likely covers your additional power draw from LEDs (though unsure if it covers the winch well).
Also, you should NOT tap off of your parking lights to power your auxiliary LEDs, a) I think your parking lights are on with high beams and 2) you'll probably melt the parking light wiring or blow the fuse. If you want to tap off the parking lights to control the LEDs you need to do it via relay.
Old November 18th, 2017, 07:30
EMSJEEP's Avatar
Re: wiring up LED's
Also, PA requires that "off-road" lights be covered while on the road. I've been stopped for lights (while off) covered by brush guards and not opaque covers. Whether they are driving lights or off-road lights will be at the discretion of the cop and based on color, aim and mounting position.
Hey wiring gurus!!! **ISO PDC wiring pin replacements** hot_rod_hooligans OEM Tech Discussion 0 September 24th, 2014 15:12
WTB 2000 XJ Engine Wiring harness and/or Complete engine with wiring harness Better_than_Tom SoCal For Sale 28 July 22nd, 2013 19:56
Wiring Gurus: Help! 1988 Header Panel on 2000 Wiring Mtb Jak Modified Tech Discussion 12 April 14th, 2011 07:21
Wiring Gooroos: Determine Wiring Load keith_b00ne Modified Tech Discussion 12 November 9th, 2010 19:30
Wiring?????? Jeepm@n OEM Tech Discussion 1 August 14th, 2007 15:49
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
