Old November 17th, 2017, 17:40
BALTANAKT BALTANAKT is offline
Changing thrust bearing with crank in motor? Is it possible?
I have heard it is possible but looking for confirmation and any guidance available on the subject. Is this impossible? Difficult? Not too bad?
Thanks in advance.
Old November 17th, 2017, 18:45
old_man's Avatar
old_man old_man is offline
Re: Changing thrust bearing with crank in motor? Is it possible?
If you have a lift to give clearance pulling the oil pan, it is a cakewalk.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old November 17th, 2017, 18:54
No lift, but I can certainly drop the front axle some other way.
Will give it a shot over the weekend.
Thanks
Torque specs for "thrust bearing cap" SicNastyXJ OEM Tech Discussion 12 December 15th, 2011 21:00
232 crank vs 258 crank | race stroked motor Nick675 Jeep Street and Performance 3 September 2nd, 2009 18:25
Changing hub bearing now brakes are shot Combatcm OEM Tech Discussion 13 February 23rd, 2009 12:26
thrust bearing failure Rockhound OEM Tech Discussion 2 May 5th, 2007 17:48
Changing front bearing retainer seal on AX15 XJNASH OEM Tech Discussion 2 May 23rd, 2006 21:25
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
