Old November 17th, 2017, 15:04
Intellect Intellect is offline
What inline check valve should i buy? Where cna i buy one?
I cant find this ancient part # 16149068988, i have a 1995 4.0 cherokee. Has a fuel bleed off issue. 3 new pumps 3 new pressure regulators, new injectors, and 2 new fuel filters later, i am DONE chasing the issue. What is an alternative to the bmw check valve? Any check valves anyone can recommend? Dont want to cut my metal lines, i will probably put it in the rubber line before the filter. Any tips, advice, etc? Dont want to do anything risky, but this should be safe with the return style set up right?
Old November 17th, 2017, 15:15
Re: What inline check valve should i buy? Where cna i buy one?
https://www.amazon.com/gp/aw/d/B01LY...HFJSGKNK&psc=1
Will this work?
Old November 18th, 2017, 09:25
UncleSarge58's Avatar
UncleSarge58 UncleSarge58 is offline
Location: SomeWhere in N. DFW, TX. Home is In the Arkansas Mountains!
Yes. It Will Work.
Have Similar Check Valve on my 96 XJ & it Works just Fine.
Better Location is After the Fuel Filter, In the Rubber Line Before the Hard Line.
Will Keep the Check Valve from Getting Clogged.
UncleSarge58
Old November 18th, 2017, 11:53
Originally Posted by UncleSarge58 View Post
Yes. It Will Work.
UncleSarge58
I ended up buying the ancient bmw part # from some random website that says itll take 14+ days to get here lol. If it gets canceled im going the amazon route than though. Was just worried it wasnt rated for the high psi cars are.
And i think we were talking the same spot. I was talking the rubber line, right after the fuel filter, on the motor side of the filter.
Sent from my Moto G (5S) Plus using Tapatalk
Old November 18th, 2017, 11:54
Yes. It Will Work.
UncleSarge58
Where did you get yours?
Installed BMW inline check valve and now... xjh3 OEM Tech Discussion 15 July 31st, 2008 08:54
Inline Check Valve xjh3 OEM Tech Discussion 5 July 12th, 2008 13:48
BMW inline check valve? derailedbus OEM Tech Discussion 2 August 12th, 2007 19:46
inline fuel check valve COXJ Modified Tech Discussion 1 February 17th, 2005 17:14
BMW check valve ??? asatxj Modified Tech Discussion 2 July 24th, 2003 10:56
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
