Old November 17th, 2017, 06:17
SavedDad SavedDad is offline
dana 30 spline and pinion question
planning on installing a Spartan in the Dana 30...how do I tell if its a high pinion...and where do I count the splines, on the end of the axle or on the yoke?
Thanks - ken
"way to blessed to be stressed"
Old November 17th, 2017, 07:19
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: dana 30 spline and pinion question
Splines are counted on the end of the axle shafts, where they go into the carrier itself.
For low vs high, look at the pumpkin as it points to the rear of the chassis and its relationship to the axle tubes. Is the yoke lower than the centerline of the axle tubes or higher than the centerline of the axle tubes? (Note: if the axle is rotated for a large lift try to imagine it without that rotation. Ideally you should be looking at it with the pinion gear in a horizontal plane.)
Do you know what year the axle is and what vehicle it came from?
Old November 17th, 2017, 08:06
RCP Phx RCP Phx is offline
It doesn't make any difference on a D30, they all use the same locker!
HP 30 dana rebuild - pinion bearing question md21722 OEM Tech Discussion 4 January 7th, 2015 06:35
Dana 44 pinion bearing question- joshv98xj Modified Tech Discussion 14 April 30th, 2011 22:23
Question about a Dana 30 High pinion ZMfx OEM Tech Discussion 10 September 22nd, 2005 15:42
Dana 44 ring & pinion change question Stick Modified Tech Discussion 5 May 13th, 2004 12:53
Dana 30 High Pinion 3.55 Ring, Pinion, Carrier, & Spiders xj92 For Sale: Private Party Only. XJ ITEMS ONLY 7 February 28th, 2004 20:14
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
