Old November 16th, 2017, 15:46
Waynerd Waynerd is offline
2001 oil filter adapter
Just trying to find out what bolt my 01 has. I've been reading and it seems that different Jeeps have different bolts. 97-01 all have either torx or Allen. I am going to be changing O-rings next oil change. I have the T60 from when I did my WJ.
Would like to hear from owners of '01's who have changed their's and what bolt did you have. Unless anyone knows a definite if certain years used one and not the other or if they were random or what.
Old November 27th, 2017, 17:56
2X_01_Jeeps 2X_01_Jeeps is offline
Re: 2001 oil filter adapter
Both my 2001s had the torx
Old November 28th, 2017, 01:01
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
My 01 uses a T60 torx head. The clearance is tight, I took a T60-3/8" socket and punched the bit out.
A 12mm box end wrench fits the bit, which is used, along with a cheater, to access and loosen the bolt.
It was very tight, requiring using a cheater, slipped over the wrench.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
WTB oil filter adapter onetallmj SoCal For Sale 7 April 27th, 2016 00:05
oil filter adapter morgan320i OEM Tech Discussion 8 October 10th, 2012 18:10
help with oil filter adapter Lance88xj OEM Tech Discussion 12 February 9th, 2011 11:23
Oil Filter Adapter xJeepxXJxThingx OEM Tech Discussion 22 April 19th, 2009 17:10
oil filter adapter shameless defect OEM Tech Discussion 10 June 26th, 2006 17:28
