Old November 14th, 2017, 08:27
cabjeepster's Avatar
cabjeepster cabjeepster is offline
Trans mount.
Looking for one that is stock design but shorter. Is there such a mount?
Tan 1995 XJ AW4 4.0, HD Offroad Cage & Frame stiffeners, D30 (Aussie Locked), 8.25 rear w/disk brakes (Lock Right), 4.56 gears, PORC SYE, 4" Lift, 33's, etc etc...
Craig
Originally Posted by cherokeefreak You probably have an 8.8 because they came stock in some cherokees with the offroad package.
Old November 14th, 2017, 09:27
ehall's Avatar
ehall ehall is offline
Re: Trans mount.
Why stock design? They don't last with off-road abuse
my '91 beater rebuild
Old November 14th, 2017, 10:03
chickenbot chickenbot is offline
Re: Trans mount.
Maybe try this?
http://teamcherokee.com/prothane-aw4...che-1987-2001/
Old November 14th, 2017, 10:15
Re: Trans mount.
Guess I worded that wrong, it doesn't have to be same design just same bolt pattern.
Craig
Old November 14th, 2017, 11:29
ehall's Avatar
Re: Trans mount.
I've been using the StinkyFab mount for a while, its held up well http://www.stinkyfab.com/vehicle-spe...-cherokee.html
Old November 14th, 2017, 13:15
srb531 srb531 is offline
Re: Trans mount.
x 2, its built tough.
Old November 14th, 2017, 15:17
Re: Trans mount.
That's a nice looking mount. But whats the height of it. Looks about the same as stock. I need one shorter.
Craig
Old November 14th, 2017, 17:23
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Trans mount.
What do you need one shorter *for*?
As far as I'm aware, no engineered shorter mount exists. SFR modified my crossmember for me to lower my setup about 5/8".
Old November 14th, 2017, 17:32
Re: Trans mount.
the SFR one is stock height, maybe a little bit taller.
Old November 14th, 2017, 17:33
cal's Avatar
cal cal is offline
Re: Trans mount.
It is stock height. It is taller than a lot of used ones that come out because the stock style compresses with use.
Old November 14th, 2017, 18:12
sinat01's Avatar
sinat01 sinat01 is offline
Re: Trans mount.
If you want one that sets lower without losing ground clearance. get a crossmember for a 5 speed.
Old November 15th, 2017, 02:35
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Re: Trans mount.
Like Cal said, there is no low profile XJ trans mount like there are for the wrangler crowd
Old November 15th, 2017, 04:35
Re: Trans mount.
Well in the process of making a cross member out of 2x6 rec. Already cut center out and recessed as much as possible. Would like to get cross member even with lower uni rails, without clocking t-case. Need about a 1" to 1 1/2 more up to be there.
Craig
Old November 15th, 2017, 08:20
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: Trans mount.
Rust's has a 1inch drop crossmember as well.
Old November 15th, 2017, 12:25
trippled trippled is offline
Re: Trans mount.
You will have to notch the crap out if the cross member to clear the front shaft, and if you drop that low it may have some serious interference. I did a 2x4 x member flat with the rails. I recessed the mount about 3)4-1 in into the xmember and used a Daystar mount. I would've had to notch it to clear the shaft but clocked the tcase as well. If you're going thru the effort to make a flat cross member why not clock the case? It was actually pretty easy to do and nothing is below my frame rails.
trans mount bert01xj OEM Tech Discussion 4 September 29th, 2010 15:19
Trans Mount 2000bluexj OEM Tech Discussion 8 February 15th, 2010 20:33
Poly motor mount + stock trans mount = bad? -88fleXJ- Modified Tech Discussion 11 August 12th, 2009 12:42
NEW O.E. ba-10/5 trans mount Hellbent For Sale: Private Party Only. XJ ITEMS ONLY 1 July 22nd, 2009 17:38
WTB trans mount MTN4X4 SoCal For Sale 1 April 21st, 2008 21:14
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
