Old November 28th, 2017, 05:38
90xj06's Avatar
90xj06 90xj06 is offline
Re: Yet another heat issue
today was 20 out engine temp stayed around 179-182
i did notice when i switch from vent to heat my thermometer got stuck in the blend door and the heat coming out of the vents was a few degrees hotter.
does the heat to vent do anything other than move the blend door?
Old November 29th, 2017, 06:48
ehall's Avatar
ehall ehall is offline
nope
my '91 beater rebuild
Old November 29th, 2017, 13:38
sinat01's Avatar
sinat01 sinat01 is offline
Just because the blend door is moving doesn't mean it is doing its job. that was part of the issue I had with my heat was the old blend door wasn't sealing up and letting cold air in. Check out Heatertreater, they make steel blend doors for XJs
Old December 7th, 2017, 08:51
90xj06's Avatar
so i went through the FSM and apparently when the selector is in the vent postion the heater water valve is CLOSED. this would cause the heat to be sucky. in all other positions the valve is open unless in full cool mode. this explains why the heat was at 144 in bi-level a/c mode. i might go cap the vacuum line for the valve until spring.
Old December 8th, 2017, 05:32
90xj06's Avatar
does this still apply to an 88? im pretty sure i have steel doors but the sealing could be an issue.
also, in 91 they changed the heater controls to allow the water valve to operate in all modes. and i have one from a 93 so my valve does work.
so any one with a renix and bad heat performance in vent mode might want to give this a check.
Old December 8th, 2017, 07:32
dan1977p dan1977p is offline
Most also remove the useless heater control valve so water is flowing through the heater core all the time like in the newer models.
Old December 8th, 2017, 10:10
90xj06's Avatar
i want to try and avoid removing it.
Heat Soak Issue Quailman OEM Tech Discussion 44 July 3rd, 2017 17:56
yet another heat issue blistovmhz OEM Tech Discussion 9 November 24th, 2010 11:50
a/c heat issue xj_chef OEM Tech Discussion 1 October 26th, 2010 10:18
Finally solved no heat issue Dave Meyers OEM Tech Discussion 15 March 7th, 2010 21:29
no heat issue heavyhopper OEM Tech Discussion 3 December 29th, 2007 21:09
