Old November 12th, 2017, 09:18
Dragonlich1961 Dragonlich1961 is offline
Fuel soaked charcoal canister help.
I've got a problem with my 94. I got a fuel smell while running and I noticed a stain inside the rf fender. Found fuel inside the line on the canister running to the air box. Pulled the canister and found it to be full of fuel.
I know this is not correct. obviously the vents are not pluged​ and the line to the tank is free flowing.
Only two things I can think of are failed gas cap not venting or, the short line between the fuel pump and the sending unit is leaking and pumping pressurized fuel into the tank.
Thanks Chris
Old November 12th, 2017, 13:57
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Re: Fuel soaked charcoal canister help.
This can happen if you top off the tank excessively as well..
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Charcoal Canister SBpunk OEM Tech Discussion 2 August 9th, 2017 07:01
Charcoal Canister 90renixxj OEM Tech Discussion 10 March 26th, 2017 11:44
Charcoal Canister ? 2WDNICK OEM Tech Discussion 5 January 11th, 2015 18:41
charcoal canister location? faering OEM Tech Discussion 3 March 11th, 2013 21:48
Charcoal canister diagram? RichieRich OEM Tech Discussion 2 August 11th, 2008 17:38
