Old November 12th, 2017, 06:44
Intellect Intellect is offline
Looking for a affordable code reader for my 95 cherokee
1995 obd1 4.0 my dash to the left is out and i am trying to find a good code reader that will work with the under the hood port. I looked all last night and no one has anything for the 90s cherokees. I dont want to spend a crazy amount on a drb3/2. Anyone had any first hand experience with one that works? Maybe with data logging.. probably no data logging with obd1 (use to my obd2 mustangs fancyness lol) we ARE talking Jeeps here... But atleast a code reader.
Or one that does obd1 and 2 with data logging?
Atleast one that does simple obd1codes (jeep compatible)
Sent from my Moto G (5S) Plus using Tapatalk
Old November 12th, 2017, 07:12
Ralph77 Ralph77 is offline
Re: Looking for a affordable code reader for my 95 cherokee
I remember way back when we used to do the paper clip trick. It would make the check engine flash. It would be like it would flash 3 times, then 7 times, then back to 3, then 7. again and again indicating a code 37. Thing was that this was before the internet so you need the book to know what a code 37 was. Does that trick still work?
Old November 12th, 2017, 07:41
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
try to find a Snap-on"Brick" 2500 IIRC with all the adapters and cartridges ,
Should be cheap as they are about 4 generations removed from current scan tools
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old November 12th, 2017, 08:05
Anak's Avatar
Anak Anak is offline
Mostly Harmless
I will second the Snap On MT2500. Ebay should have them.
They were premium stuff in their day, but they are pretty obsolete now.
Old November 12th, 2017, 14:00
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Cycling the key three times from off to run should also pull codes, iirc.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old November 12th, 2017, 17:34
trippled trippled is offline
This. I think Innova also had a code reader that had obd1 adapters. It was around $200 last I saw.
Old November 12th, 2017, 19:23
Cant cycle the key and read the blinks, since that section of dash is burnt up. Tried fixing it a few times. But no bueno
Old November 12th, 2017, 19:24
Thank you! Ill look into it
Old November 13th, 2017, 13:27
Eh $300+ , im not sure i love my Jeep THAT much lol, its in a bit of a timeout for fuel pressure issues.
Old November 13th, 2017, 18:07
ehall's Avatar
ehall ehall is offline
This one is on my to-buy list Innova 31403
my '91 beater rebuild
Old November 14th, 2017, 02:08
Dragonslayer Dragonslayer is offline
Actron ScanTool CP9110. Be sure that it comes with the CP9113 cartridge for
1989-1995 Chrysler Systems, as well as all of the necessary cables and manual.
You might find one on eBay.
Old November 14th, 2017, 02:11
Old November 14th, 2017, 16:23
All the inovas are not chrystler 90-95 capable
Old November 14th, 2017, 16:44
Cummins90 Cummins90 is offline
I use my actron cp9185. Slow refresh rate but it pulls codes and reads live data.
Error Code Reader for 91 Cherokee Widnrf1j1 OEM Tech Discussion 0 September 13th, 2014 20:30
Code Reader tcpoland Colorado Chapter 9 February 8th, 2012 20:24
Code reader for 92 XJ marc davis OEM Tech Discussion 7 October 19th, 2011 10:48
ODB II code reader Rammin97 Sierra Chapter 6 December 12th, 2009 15:12
Code Reader Silent Jeep Street and Performance 1 December 23rd, 2005 19:19
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
