Old November 11th, 2017, 17:21
alheim alheim is offline
01' XJ AC Condenser to Radiator L-shaped mounting brakcets
Hey folks, long time Jeeper, first time posting here.
I'm in the midst of an accessory & timing belt overhaul on my '01 with 197k on the original motor, original head. I am replacing the cooling system, timing cover gasket & front seal, maybe the timing chain if it's worn, and the alternator.
Anyway, the top of the AC condenser mounts directly to the radiator's top mounting cushions via flat L-shaped mounting brackets. I accidentally tossed mine, they are deep in a New York City landfill at this point.
I can't find replacements. Guessing I'll have to fabricate something. They didn't come with my new radiator. Thoughts?
Old November 11th, 2017, 18:05
RCP Phx RCP Phx is offline
Re: 01' XJ AC Condenser to Radiator L-shaped mounting brakcets
Junk yard would be the easiest!
Old November 11th, 2017, 18:26
Heavyopp Heavyopp is offline
I might have a set on my 97 parts jeep -- I'll have to check and see if they are the same as my 2000 which should be the same as your 01
I should be able to check it tomorrow (Sunday)
Old November 12th, 2017, 16:59
Thanks @Heavyopp let me know, that would make my life easier.
@RCP Phx there are not many junkyards in NYC! I could find one but it would take most of my day. No pick n' pulls as far as I know
Old November 14th, 2017, 16:57
For the life of me I can not locate these brackets, can't even find a photo of them. It's almost a matter of principal at this point!
The brackets hold the top if the AC condenser to the top of the radiator's cushioned mounts (circled in red in photo below).
The 2001 parts catalog shows it as PN 56002231 however this part is discontinued / no longer available. See Part N. 11 in this Figure 024-250:
Additionally, the L-shaped clips that I had didn't look like the part depicted above. Did I have an aftermarket condenser or jury-rigged setup? Any ideas?
Edit: I am starting to think that mine were an improvised solution. I can recreate them.
Old November 14th, 2017, 18:26
I'm on my way out to take a look at what I have -- I'll get back to you tonight
Old November 16th, 2017, 12:35
md21722 md21722 is offline
On the factory/dealer radiators the condenser mounts are typically integrated, not separate brackets. I'm surprised they even have a bracket in the parts catalog.
AC condenser leak? Or Radiator? erykv1 OEM Tech Discussion 4 January 28th, 2016 10:26
WTB Radiator, fan shroud, maybe a/c condenser, PLUS MORE ghettocruiser NAC Classifieds 13 January 13th, 2014 08:27
Can i Remove the A/C condenser without removing the Radiator??? jomeza001 OEM Tech Discussion 9 September 4th, 2013 16:35
Radiator replacement/condenser weekendmech OEM Tech Discussion 1 February 20th, 2008 18:42
radiator and a/c condenser nebish OEM Tech Discussion 2 April 12th, 2004 13:09
