Old November 11th, 2017, 08:27
srb531 srb531 is offline
motor mount torque value
of the large bolt, just installed some ironman fab rubber in the center ones. whats the recommended torque for the big bolt, ive heard too tight can make the vibes worse ? right now i barely snugged them & there are some vibes, will tighter help of make it worse ?
Old November 11th, 2017, 12:28
Francesco Francesco is offline
Re: motor mount torque value
I got mine pretty damn tight. Gotta remember that they do have to break in, mine had a little more vibrations than I was used to at first. After a few miles, its much better.
Old November 11th, 2017, 13:57
found out the oem spec is 48 lbs. , so i just went w/ 50 lbs . for now. ive heard they do need to break in, i shall see.
Old November 11th, 2017, 14:42
sinat01's Avatar
sinat01 sinat01 is offline
The mount will vibrate, it will lessen with time. Ive had mine since march, and it rarely vibrates bad enough to notice.
Old November 11th, 2017, 20:05
so it should be ok in about 8 months ? damn.
Old November 12th, 2017, 11:52
sinat01's Avatar
it was only bad for about a month, also only has like 4k miles on it too
2 Questions: engine block motor mount bolts & dana 30 pinion nut torque ??'s XGarfX Modified Tech Discussion 13 April 17th, 2012 07:20
Poly motor mount + stock trans mount = bad? -88fleXJ- Modified Tech Discussion 11 August 12th, 2009 12:42
Transmission mount/torque arm XJ AV8R OEM Tech Discussion 9 April 29th, 2008 00:23
Motor Mount torque spec? Redsnake OEM Tech Discussion 1 August 14th, 2006 11:10
Motor mount torque? Osprey413 Modified Tech Discussion 3 January 22nd, 2006 14:51
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
