Old November 10th, 2017, 18:31
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
97 rear O2 sensor harness side connector
Need the part number, PLEASE, and a source(s) if possible for the harness side connector for 1997 Cherokee rear (after the Cat) O2 sensor.
A new friend....new guy in town, needed help.... Doing a freebie,... I found both sides of his rear O2 sensor wire assy were ripped out, nothing but 4 bare wires left on both sides.
Only 6" of wire left on the sensor side (and no idea if it is OK, or not), and I have my doubts PVC covered auto patch wire that close can handle the Cat Converter heat???? So thinking new sensor instead of a wire only repair/patch. If I do that I will need a new factor style connector for the bare wire harness side too.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old November 25th, 2017, 18:29
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Re: 97 rear O2 sensor harness side connector
You could probably get away with direct connecting the wires as a temporary fix. Although, a new sensor is your best bet.
Send me a pic of the new sensor connector . I may have one I can ship you.
Either way you go, remember not to solder the wires. The lead will contaminate the sensor in the long run.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old November 25th, 2017, 18:55
Ecomike's Avatar
NAXJA# 2091
Lead solder ? O2 sensor contamination? Where did you hear that?
I found the parts at Amazon... the guy never came back, doubt he will, still owes me money.
Old November 26th, 2017, 09:26
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
That harness plugs in by the back of the engine. You could probably find it at a pull a part. My 98 had the plug ripped off and that is what I did.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old November 26th, 2017, 16:31
four_shot's Avatar
How 'bout it Gonzo
Tech school,& GM's basic electronics training.
The sensor uses the oxygen that wicks in through the sensor signal wire as part of the electrochemical reaction in the oxygen measuring process. It took me a while to get my head wrapped around. the lead in the solder contaminates the "back side" of the element just like leaded fuel contaminates the "front".
4shot
Old November 26th, 2017, 17:01
Ecomike's Avatar
NAXJA# 2091
But its not like solid lead is going to crawl down the wire from the solder joint way down to the sensor surface. So is it the trace lead fumes from soldering that do it? Even that seems like a stretch, just warp a sealing bag around the O2 sensor with DUCK TAPE first? Most of today's electronics solder is now supposed to be lead free???
We use to make jokes about how all the soil along side all the US highways were legally US EPA hazardous waste in the 1980s due the leachable lead levels in the soil, LOL. And then there are those leaking lead acid batteries under the hood, hmm.
Interesting though. I do know that Silicates (silicone oxides) from the old green antifreeze accumulates and ruins the O2 sensors. And Phosphorous and ZDDP Zinc from the motor oils, LOL.
Don't get me started LOL
Old November 27th, 2017, 18:44
four_shot's Avatar
How 'bout it Gonzo
Trace lead leaches down through the wire. I've seen it happen with coolant too.
"Mam/sir, you need a coolant temp sensor, an ecm and the wire harness between them. That'll be $1500."
That never gets old. lol
4shot
Old November 27th, 2017, 20:44
Ecomike's Avatar
NAXJA# 2091
On second thought, since those sensors operate at over 600 F, and the wires are attached to it, I guess trace lead vapor can diffuse under the insulation at the solder joint to the sensor. Just read the UK guys saying lead solder in the gas tanks from too much alcohol and injector cleaners does them in too.
What is this connector / sensor? SouthSeaPirate OEM Tech Discussion 7 July 22nd, 2017 21:29
Corroded connector harness for rear passenger tail lamps Hilifthero97XJ OEM Tech Discussion 3 April 13th, 2016 22:49
Harness connector question premoxj OEM Tech Discussion 27 March 12th, 2013 14:03
How to de-pin front harness connector? N8N_99xj OEM Tech Discussion 4 August 25th, 2012 16:15
95/96 XJ Heater/AC Fan Control Harness Connector ??? KD3NE_ OEM Tech Discussion 2 February 13th, 2011 13:32
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
