Old November 10th, 2017, 13:58
Vernicious Vernicious is offline
Temp gauge reading low
I think my temp sensor is going south, but I wanted to see else it could be. I was driving home from work the other day and the temp outside was about 35*. I was sitting in traffic and my temp gauge went down to 2 ticks below 210. It usually sits about half way between 210 and the tick below it. The next day I drove to work and sat in a little bit of traffic. The temp was about 25* out and this time it came all the way down to the tick above 100*. I was thinking an air bubble could create this, but the last time I had one of those the temp went high, not low. I recently did a coolant flush and I don't believe that my system is working that well
Old November 10th, 2017, 14:47
Bent's Avatar
Bent Bent is online now
Only Slightly Psychotic
Re: Temp gauge reading low
I replaced the sender on my son's 96 and the gauge still reads hi. Either a bad sender or a wonky gauge. The temperature checks out at 210 +/- with an IR thermometer so for him (me) it's not worth the hassle to persue it further.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Old November 10th, 2017, 15:04
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Any helpful details about the vehicle in question ?
How old is the thermostat ? Is it sticking open ?
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old November 10th, 2017, 17:21
RCP Phx RCP Phx is offline
Put a scanner on it! What year and motor do you have?
Old November 10th, 2017, 20:41
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Had this problem in my 98 recently.Random problem with the gauge dropping to 0,Some time in its previous life the wires from the O2 sensor were ripped off.
They were repaired,but a wire tie was used to pull the wires tight and pulled connection to the temp sender(sensor)loose.
I loosened the wires,un-pluged the connection,backed the sensor out,tightened it up and re-pluged the connector.
Cleared the fault and all is still well.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old November 11th, 2017, 20:22
My apologies, I meant to put specifics... It's a 99 XJ with the 4L and an AW4. Other than the lift it's all stock. The thermostat is a possibility. When I did the flush I planned on replacing the water pump, thermostat, fan clutch and rad cap. However, there was so much stuff left in the radiator and heater core I opted to just change the cap only. Over the winter I'm picking up a new radiator, heater core and hoses to swap out once the temp heats up a little. I have no idea how old the coolant system is in this vehicle. I've owned it for 2 years so I know the components are at least that old. I also have a trans cooler, and plan to replace the trans filter and fluid at the same time.
Old November 12th, 2017, 10:59
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
As suggested by RCP Phx, hook up an OBDII scanner and see what the digital temperature reading is.
Use an infrared thermometer to check the temperature of the thermostat housing, using the highest temperature detected as the 'right' temp.
If the thermostat housing reading is much different than the infrared reading, then sensor is probably bad.
I tried several sensors, on one of my Jeeps, before finding one that gave the correct temp, one that both the scanner and infrared thermometer agreed with.
Interestingly, a new Mopar sensor was off, a Delphi sensor was right on.
I suspect that with an old, un-serviced, cooling system, there is a good chance the thermostat is failing.
Changing a thermostat isn't a big job, you might want to do it now, if you are not planning on the cooling system rebuild in the near future.
It would also improved the heater's performance, nice when it's 25 outside.
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old November 12th, 2017, 18:08
Lazy, thanks for the info. I think you guys are onto something with the thermostat. Ironically when I noticed the real low temp it was about 28* out and my heater was blazing hot. That's what made me question what was really going on. I may just swap out the thermostat next weekend to see how it goes.
For the record my temp sensor is only holding on by the wires. I had planned on replacing it with the rest of the cooling system in the spring. If I have to do it now, I will.
Old November 13th, 2017, 22:03
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
What kind of shape is the sensor in?
For the record my temp sensor is only holding on by the wires..
Oh, nevermind.
1990 XJ - 4.0L AW4 It's white.
1988 MJ - 4.0L AW4 It's green.
B&M Transmission Temp Gauge - No Reading TheSloMoShow Modified Tech Discussion 24 December 27th, 2016 22:30
Temp gauge not reading accurately Ben824 OEM Tech Discussion 18 August 20th, 2016 15:24
Temp gauge reading super low? jeepfreak1020 Modified Tech Discussion 1 January 25th, 2013 08:23
engine temp. gauge no reading Ben824 OEM Tech Discussion 10 March 9th, 2007 11:37
Fixed high temp gauge reading 8991XJ OEM Tech Discussion 6 September 14th, 2006 17:19
