Old November 10th, 2017, 10:29
Intellect Intellect is offline
What does this burnt plug go to.
95 4.0 4wd cherokee , my 4wd light/abs light/check engine light stopped working recently and i smelt smoke... Im fixingthis either way, but curious what its for. I went to cut it to splice and i heard a buzz like a door buzzer lol (forgot to disconnect battery which im doing now)
Sent from my Moto G (5S) Plus using Tapatalk
Old November 10th, 2017, 12:18
Well i replaced the burnt wiring... Still no dash lights...
Old November 10th, 2017, 12:24
emx721 emx721 is offline
Re: What does this burnt plug go to.
https://www.cherokeeforum.com/f2/no-...-fixed-143840/
Old November 10th, 2017, 12:40
Originally Posted by emx721 View Post
My rpm and mph lights work, all lights except the ones to the left. Different than that link
Old November 10th, 2017, 15:41
lawsoncl lawsoncl is offline
The connector is the headlamp delay module, C233.
#1 White/blck and White/Orage are fused ignition switch output.
#2 Tan/black is headlamp switch output
#3 Black wires are ground
#4 Gray/Orange is fused B+ 12 volts.
You got the right fuses in there? Shorted headlight maybe?
Old November 10th, 2017, 17:21
Ah, just saw your other posting about smoking the tell-tale indicator. The white/orange wire feeds those dash lights, which explains how that wire got fried.
https://www.naxja.org/forum/showthread.php?t=1144717
tap stock D35C fill plug hole for real plug? N8N_99xj OEM Tech Discussion 0 February 4th, 2012 08:36
#1 Plug Burnt at 4k miles dustybill OEM Tech Discussion 3 July 21st, 2009 14:55
#1 plug burnt up txcwby88 OEM Tech Discussion 8 January 8th, 2009 17:11
how burnt is too burnt? crazyoffroader OEM Tech Discussion 7 January 9th, 2005 14:42
Burnt xj crazyoffroader OEM Tech Discussion 1 November 1st, 2004 17:54
