Old November 10th, 2017, 07:38
Intellect Intellect is offline
Im in a junkyard and have a fitment question
This part on my 95 4.0 4wd went bad, i found a 94 2wd 4cylinder, so will it work? Are the electronics inside for the 4wd light even on the 2wd models? If not will it still work for check engine light? My biggest issue is i cant read my obd1 blinks because this section burnt up one day.
Also, can i seperate this section from the cluster? Thx for any help! Stuck at lkq until i see a reply lol
Sent from my Moto G (5S) Plus using Tapatalk
Old November 10th, 2017, 07:42
I know i have to brake the housing, as you see here, it has its own 2 screws, ill just dremel my old one off on my xj, and they will for now on be two seperate pieces from the cluster, im asking, should this plug into my 6cyl 95 4wd cherokee? Cut and splice?
Old November 10th, 2017, 07:54
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: Im in a junkyard and have a fitment question
Pictures are a bit on the large side, so pardon me if I am missing something, but it looks to me like all you need to do is remove that plug in the middle and then you could take that thin sheet that has all the copper conduits for the bulbs. Odds are that is all you need. Unless yours burnt up in some fashion that it damaged the face or perhaps the plug, in which case I am thinking you have an additional problem that is even a higher priority.
Any details on how your old one failed? Other than a bulb burning out, I can't think of any good reason for that part to die. I have seen a few larger speedometer cluster equivalents to that with problems, but I think their size and extra room to flex has been the driving factor there. This piece is pretty small and looks to be fairly well retained.
Old November 10th, 2017, 07:57
The fuse popped 3 times in a row,(for cluster and this, they share a fuse) i was impatient and trying to read blinking obd1 codes. Used a jumper wire in place of a fuse... Turned key, SMOKE GALLORE luckily my dumb self realised i dont want to burn my xj down, turned key off. In that 4 seconds only this portion stopped working thank the heavens. The gauges radio speedo etc didnt get hurt.
Old November 10th, 2017, 07:59
Hopefully this pic is smaller.. using tapatalk app so pardon me. So your saying i should be able to use that plug/copper paper (forget name) on my 6cyl 4wd, even tho this is a 4cyl 2wd at the yard?
(I work with radios a lot so I imagined this was a delicate ribon type cable i couldnt take off or touch too much)
Old November 10th, 2017, 08:15
Thank you! I'll post results
Old November 10th, 2017, 08:33
Anak's Avatar
Mostly Harmless
There you go.
Just don't fold it up and stuff it in your back pocket.
I doubt there are many, different, versions of that piece. I expect it will work fine.
Only question is what went wrong such that your old one burned up. I can't see how that piece would have a short in it. If you are still blowing fuses you will have some diagnostic work ahead of you.
Old November 10th, 2017, 10:03
Well mine is not burnt up, everything looks fine. But the check engine/4wd/abs light up sections not working.. no more fuse blowing though.
Old November 10th, 2017, 10:11
Copper checks good, bulbs check good, none of the lights work on this circuit though. I tried researching it but most people with this issue there entire gauge cluster goed out... Mine works fine.
Old November 10th, 2017, 10:22
Winner winner chicken dinner, i assume this goes to the light cluster?
Old November 10th, 2017, 13:58
Anak's Avatar
Mostly Harmless
I can't place where that is, but you are certainly on the trail of something.
Next question is where does that wire go and what is wrong to cause it to melt down like that?
Old November 10th, 2017, 17:26
lawsoncl lawsoncl is offline
Also posted in https://www.naxja.org/forum/showthread.php?t=1144719
That's the headlight delay module. Wiring diagram shows the white/black goes to the fuse block. The white/orange on the same pin feeds the indicator lights on the dash that you said shorted, and continues on to feed the remote keyless module and the overhead console. I would inspect the whole length of that wire between where you think it shorted and the fuse block.
Old November 10th, 2017, 23:43
The white and black? Wiring isnt my strong suit. Ive done some direct engine swaps but thats all plug and play. Radios and lights and stuff. I understand basics to relays and ohms etc. But the white and black goes to the thick loom that goes throught the fire wall...unless it comes back in before it goes to fuse block. The white and black was burnt pretty far, it went as far back as where the thick loom goes through firewall. I cut the black plastic shrinkwrap off the loom because i was tracing where the burntness stopped but ever time i went an extra inch..it was still burnt. I think your onto something. Possibly a good idea to just run a new wire directly from fuse block to the plug/silver guy the plug plugs into.
1995 4.0 4wd country. Just making sure same page model wise.. cause i thought i read on a forum that, that set of lights (check engine,abs,part time, etc) ties into the gauge cluster wiring, because the gauge cluster fuse is the one i idiotically put a jumper wire in, before i smelt smoking and the lights to the left stopped working. (Luckily after 4 seconds i learned i was pulling an idiotic stunt and jerked that key off and jumper wire right out)
Old November 10th, 2017, 23:47
Also, pardon my double posting.. sort of... The other forum you replied too, i am just now seeing, i could not access it before, tapatalk glitches.
Old November 14th, 2017, 16:11
I fixed that wiring... Lights still out.. anyhelp? Abs cel etc section doesnt work.. gauges do and backlights do
1990 XJ heater box fitment question. Monster3663 Modified Tech Discussion 1 July 13th, 2013 15:52
hitch fitment question zax200 Modified Tech Discussion 2 June 4th, 2010 12:01
Tire fitment question BIGSLVRXJ Tow Rigs and Trailers 1 April 30th, 2008 13:03
Tire fitment question ty20404 Modified Tech Discussion 6 March 17th, 2007 22:18
