Old November 9th, 2017, 17:13
Intellect Intellect is offline
Simple fuel pump questions that i cant find online
1) is the hole circled in the first picture on the top of the fuel pump normal? It looks threaded like a screw should be
2) i had a instant fuel bleed off issue,(30psi-0psi as soon as i shut it off) after a new pump, regulator, and diagnosing my injectors i found out the gosh darn rubber hose seen in second picture was leaking BAD. I replaced it with 3rd picture hose/injector clamps and now it just weeps, is this normal? (A slight weep of fuel, or will it cause an overnight bleedoff) (what is pictured is new hose that weeps at bottom, where it touches light blue part of pump)
3) i have the return style fuel set up, if i continue to bleed off overnight, who can give me detailed instructions on a jimmy rig inline check valve, (size parts, parts, retail stores who have them etc)
I have an offroad full weekend event and have been chasing a fuel bleed off issue all week.
1995 jeep cheroke 4.0 inline 6, many new parts, 247k miles, once running she purrs besides a little exhaust leak and occasional lifter tick.
Thanks in advance for any help! Its a weekend toy and trail rig, so if it comes down to it bleeding out overnight tonight again, i have diagnosed all i could, next is inline check valve and call it a day!
Sent from my Moto G (5S) Plus using Tapatalk
New Fuel pump...questions on starting Cottontail OEM Tech Discussion 2 March 1st, 2006 17:52
Fuel pump questions. PFunk242 OEM Tech Discussion 4 August 26th, 2005 06:32
A few fuel pump questions and 1 exhaust questions Cottontail OEM Tech Discussion 3 August 9th, 2005 18:16
MJ Fuel pump questions gr8tires OEM Tech Discussion 0 September 5th, 2004 04:14
Fuel Pump Questions?? BIGSLVRXJ OEM Tech Discussion 8 August 30th, 2004 18:32
