Old November 9th, 2017, 14:56
N8N_99xj N8N_99xj is offline
Truck-Lite LED aiming?
I don't have an aiming machine so I'm doing this eyeballically. Also, when I got my Heep not only were the headlight sockets badly corroded but the buckets weren't even close to straight, I looked all crosseyed driving down the road. Now that I'm driving home from work in the dark every day and probably to work in the dark real soon, it's time to get these dialed in - up until now they've been aimed way too low.
There are really pronounced bright spots on low beam, I'm assuming I should ignore those and concentrate on the horizontal cutoff? The pattern seems really odd, like those bright spots would cause glare in the mirrors of the car in front of me.
Old November 9th, 2017, 15:44
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: Truck-Lite LED aiming?
Parked it about 30 feet from a nice wall on level ground, aim the headlights so the cutoff is just a couple inches lower than the headlight. I usually measure mine at say 30" from the ground to the bottom of the light, and set the cutoff for about 28".
Obviously this method will work on any vehicle if the ground is flat and level, your numbers will vary based on lift and tire size of course.
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old November 10th, 2017, 06:53
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
A simple Google image search brings up headlight aim diagrams with instructions and measurements, including the one from your Jeep Service Manual.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old November 10th, 2017, 10:03
techno1154's Avatar
techno1154 techno1154 is online now
Yes. All the above posts + they should be aimed when the high beam is on. The low beam should fall correctly after they are aimed correctly if,.. and a big IF the bulbs/sealed beams are of a good quality.
One of the bulbs in my round eyes headlamp went out. I replaced it with a discount store offering and had a terrible light scatter especially on low beam. I was never happy it.
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Truck-lite's new LED headlight for XJ's stumpXJ Modified Tech Discussion 273 December 4th, 2016 17:09
FS--TRUCK-LITE HEADLIGHTS CobraMarty For Sale: Private Party Only. XJ ITEMS ONLY 3 October 10th, 2012 00:06
Billet Al Lite-Grip Mag-Lite Bracket XpedientJ NAC Classifieds 1 October 25th, 2007 15:23
Lite Truck tires? Shifty OEM Tech Discussion 11 November 3rd, 2004 06:35
