Old November 10th, 2017, 13:50
Slimer Slimer is offline
Re: XJ tries to change lanes when letting off gas
I notice mine more at 60mph +, but it's a auto, more noticeable on a manual. Slimer asked me to drive his but I can only operate a auto!
Mine is an automatic too.
Old November 12th, 2017, 10:42
Rod Knee's Avatar
Rod Knee Rod Knee is offline
I have a rear Detroit locker and mine does what has been described in this thread too, but not to the extent it force a lane change or anything close to it. I am just always mindful of what I am driving and don't have a problem...
Old November 12th, 2017, 18:37
deesiexj's Avatar
deesiexj deesiexj is offline
Not to totally hijack this, but what is it about the Detroit locker that causes this behavior?
I'm weighing my options for a rear locker and am curious if this is something specific to the Detroit, or more common in other types of auto lockers as well
Old November 12th, 2017, 22:15
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
It's the unlocking of the locker when entering a corner.
Usually not much of an issue. It is noticeable but no where near as bad as the op said which leads me to believe he has worn leaf spring\shackle bushings compounding the issue.
Old November 13th, 2017, 11:42
jrowell's Avatar
jrowell jrowell is offline
My Detroit Locked 44 on 35's and 5.13's does not have this problem.
Old November 14th, 2017, 12:21
If you are local, you are more than well come to come for a ride with me, or possibly drive mine. I will be replacing the rear shackles with the Rusty's Boomerrag Shackles.
http://www.rustysoffroad.com/jeep-su...-shackles.html
Old November 14th, 2017, 13:08
Afireinside Afireinside is offline
I have had this happen before. Check how tight your u-bolts are. Mine was a broken spring pin caused by loose u-bolts.
Good luck
Old November 14th, 2017, 20:48
scoobyxj's Avatar
scoobyxj scoobyxj is offline
It's the automatic locker. Not just because it's a Detroit. When not locked the power is being routed through only one side of the locker, and when you let off the gas the natural pulling force disappears making it feel like it pulls the opposite way. Worn suspension component will amplify the effect.
Old November 14th, 2017, 21:27
old_man's Avatar
old_man old_man is offline
Besides making sure all the suspension mounts are not moving and all the bushings are good, make sure the rear tires have exactly the same air pressure, especially with a Detroit.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old November 15th, 2017, 12:51
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
FWIW, I never had this issue with my Detriot.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old November 16th, 2017, 13:33
See how crazy this is? Some people swear it is my locker while others swear it is not! I have to figure this out before I spend $1,000 on another ARB locker that may or may not fix the problem!
Old November 16th, 2017, 14:10
deesiexj's Avatar
Thanks for the input everyone. Doesn't necessarily give Slimer a smoking gun, but it is helpful to know that the effect is often exaggerated by worn suspension components
Old November 16th, 2017, 14:37
Rockwood Rockwood is offline
Worn suspension, or like me, no sway bar. Either way, locked diffs make your Heep go straight. Unlock the diff, and now you know why your diffs came unlocked from the factory. For pavement, you want to limit slip as little as possible to maintain maximum traction. For offroad, you want zero slip.
Old November 16th, 2017, 15:04
So I still have a sway bar up front. Everything seems tight, in fact most everything is almost new, including the Dynatrac axle and Tereflex steering up front. The only part of the suspension that I could find that is old is the rear shackles are original and it looks like the upper shackle bushings might be bad. I am replacing the shackles soon. Other than that, I have no idea what it could be.
Old November 16th, 2017, 15:20
Physics. Locked diffs make shit go straight. You naturally add steering to force it around a turn. When you remove the reason you needed more steering, you "change lanes".
After TDS, letting everything go at cost. RWKHausSupply SoCal For Sale 3 March 8th, 2012 11:56
odd noise when letting off gas dan302492 OEM Tech Discussion 10 August 22nd, 2008 17:13
not letting me change my email gunthagunth User Support, Questions and Suggestions 2 February 15th, 2006 17:38
Just letting off some steam theslacker Non-Tech / Off Topic 0 March 26th, 2005 22:16
Thank you for letting me serve Andy Steiner SoCal Chapter 4 March 3rd, 2005 12:33
