Old November 9th, 2017, 10:26
Pelagius Pelagius is offline
Additional Questions on Drum to Disc Conversion
Alright hive mind,
I am in need of some opinions and addition learnin, on the topic of drum to disc conversion for my XJ D44. In doing my research I have determined that using the backing plates from a ford explorer with a ford 8.8 rear axle will be the way I want to go. Pretty much like this thread here:
http://www.naxja.org/forum/showthread.php?t=967146
Just got a few additional questions:
- What are the ways to attach the soft lines from the caliper to the hard lines on the axle?
- Should I get the calipers from the JY when I get the backing plates or purchase new ones?
- Will 15 wheels fit on this set up?
- I just had all the bearing and seals replaced on my rear axle only about 1500 miles ago. Should I get the Terraflex spacer and new bearings or get the TJ bracket and cut it out so I will not have to remove and press on new bearings.
Thanks in advance for your input!
Jason
Old November 9th, 2017, 10:34
RCP Phx RCP Phx is offline
Re: Additional Questions on Drum to Disc Conversion
I used standard flex lines and my original hard lines. New calipers are cheap so it's not worth trying jy ones. 15" wheels might fit depending on the backspacing. I wouldn't cut the retainers, just press on with new collars.
Old November 9th, 2017, 10:37
XJsportG's Avatar
XJsportG XJsportG is offline
SouthEast #4328 (RVA)
1. Hardlines should screw right into the soft lines for the calipers. You will have to find a way to mount the softline and then bend the hardline to the connection. (I can post photos of how I did mine when I get home)
2. You could get JY calipers and then use them as cores for new ones. Either way works, whatever you wallet prefers.
3. Yes 15" wheel will work, I run them. 3.75" BS
4. I used the XJ 44 retainer with spacer as mentioned in the thread you linked. I was building my axle new, so I had to cut mine off anyways.
RVA
Old November 9th, 2017, 17:07
ehall's Avatar
ehall ehall is offline
I drilled a couple of holes into the perches, one for the bolt another for a positioning tab. I could probably use front braided lines for this setup and go over the leaf, will try it next time.
TJ axles and brakes so can't directly address your other questions
my '91 beater rebuild
Write-Up 8.25" Rear Drum to ZJ Disc Brake conversion WB9YZU Modified Tech Discussion 7 July 9th, 2013 19:57
drum to disc conversion. 90xj06 Modified Tech Discussion 12 July 11th, 2010 21:36
Rear Disc Brake Hardware (from ZJ for drum-disc conversion) LocoJeeper NAC Classifieds 7 September 16th, 2008 14:03
HP44 drum to disc conversion Smittty9785 Modified Tech Discussion 20 May 28th, 2008 14:06
'95 XJ drum to disc conversion? Silent Modified Tech Discussion 1 February 11th, 2006 18:24
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
