Old November 4th, 2017, 15:43
airbusmeister airbusmeister is offline
Cody's 96' 5 speed build!
Well cylinder six finally went in my 96' 4dr, 5spd, so I did what we would all do. I Stripped out the entire interior, pulled the carpets, wheel liners, flares and started sanding the floor pan.
I figure I might as well start a build thread since it has been apart for some time now and i decided to break it down even further.
The plan is as follows.
Long arm kit
4.7 stroker
Re-gear
Re-paint
Trim Fenders
New rear bumper
New roof rack
Re-fresh interior, new carpets, sound deadening etc.
and then all the bits and bobs that go with that.
Old November 4th, 2017, 16:44
Re: Cody's 96' 5 speed build!
So i guess we start with the whole reason I parked my Xj.
[IMG][/IMG]
As you can see cylinder 6 isn't too happy
Old November 4th, 2017, 16:45
So i started pulling the rest of it apart and figured i might as well go ape shit.
i started striping the motor and interior
Old November 4th, 2017, 16:50
I had a wet carpet in the passenger side foot well so why not.
I also had a family of ants living on my tranny tunnel. Caused me a couple of chinese fire drills when they would start pouring out of the center console
I cleaned up the floor pan and began to sand it down and ready it for bedliner
Old November 4th, 2017, 16:56
I started to roll on the bed liner and found one rust spot , i had not discovered previously, about the size i quarter.
I rolled on about 2 coats of liner, but still need to repair the rust hole.
The dogs thought they would help too....:0
Old November 4th, 2017, 17:03
My hoods clear was peeling and the bottoms of the doors and quarters were pretty rough so i sanded primed and got one coat of bed liner on them. I don't really care for the look of the roll on, so i plant to redo it with a spray on.
Wiper arms too!
Old November 4th, 2017, 17:10
I guess i should have given you guys a starting point too, I loved my jeep the way it was but there was definitely room for improvement. These were right before our last road trip loaded down.
Adam's 98 5-speed Build 5-Speed XJ Modified Tech Discussion 360 February 11th, 2017 16:15
2000 jeep xj 5-speed build megamanmojo North Atlantic Chapter 57 September 5th, 2016 18:37
Bogging at freeway speed, causing heat build up oldskool67 OEM Tech Discussion 3 October 3rd, 2014 04:08
Adam's 98 5-speed Build 5-Speed XJ North Atlantic Chapter 18 October 5th, 2011 21:22
Cheap Speed Build Curser JeepSpeed, Prerunner and Competition Tech Forum 8 April 26th, 2010 21:35
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
