Old November 2nd, 2017, 23:52
Porch Puppy's Avatar
Porch Puppy Porch Puppy is offline
Thread Killer
How to build a Cherokee?
Seriously how do you build a Cherokee.
Old November 3rd, 2017, 02:40
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Re: How to build a Cherokee?
Built 4cyl and SO cord for wiring with a $2500 gauge cluster
Old November 3rd, 2017, 05:44
Jeep Driver Jeep Driver is offline
Old November 3rd, 2017, 06:30
srb531 srb531 is online now
build is a relative term, but always begin by having plenty of money to waste.
Old November 3rd, 2017, 07:05
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Open ears and an open mind.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
Old November 3rd, 2017, 07:44
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
Wheel
Break stuff
Upgrade stuff
Repeat till you or the Jeep die
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old November 3rd, 2017, 11:08
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Lefty loosey, righty tighty ?
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old November 3rd, 2017, 12:19
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Just empty every pocket.
Old November 3rd, 2017, 13:55
denverd1 denverd1 is offline
build????
I thought it was best to buy one off craigslist that's already lifted and "built" with 20" rims and rubber band tires... No?
Old November 3rd, 2017, 16:06
Jes's Avatar
Jes Jes is offline
www.urfracing.com
We can never have nice things...
Old November 3rd, 2017, 16:12
Bent's Avatar
Build Jes, build.
Old November 3rd, 2017, 16:32
Thread Killer
I only have $500 to do this....
Old November 3rd, 2017, 16:34
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Sway bar disconnects, good 235 tires unless your willing to trim then 31's, and revovery points
Old November 3rd, 2017, 16:36
Jes's Avatar
Jes Jes is offline
www.urfracing.com
You should probably fall down on a knife somewhere.
Old November 3rd, 2017, 20:15
Kaczman Kaczman is offline
Lurker
$500? You can build 5 XJ's for that. I'd start with a front leaf swap.
All fluff, no substance.
My Jeep Cherokee build: 1997 Cherokee Sport workman13 Modified Tech Discussion 8 January 21st, 2015 08:51
93 Cherokee 2dr Build HRKBackwoods North Atlantic Chapter 21 March 2nd, 2014 00:04
cherokee build sheet jdujeeper OEM Tech Discussion 2 July 1st, 2011 22:00
Another cheep cherokee build lorax81 Modified Tech Discussion 7 December 6th, 2009 00:15
which cherokee to build jar Modified Tech Discussion 2 February 28th, 2005 16:41
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
