Old November 2nd, 2017, 03:59
jonb8's Avatar
jonb8 jonb8 is offline
Tucking the winch
Since I started pulling the teardrop I've been Ok with a new coolant system but I'm wanting to go out west again next summer and I'd really like to use the air conditioning. So I need to get the winch out from in front of grill and install a tranny cooler.
Old November 2nd, 2017, 04:44
need-a-bow's Avatar
need-a-bow need-a-bow is offline
Tucking the winch
Nice! TwoDoorRob made his and my bumpers out of a custom 3/16 C channel. Mine is aboit 3/4" in front of the header panel, his is flush
Sent from my SM-G955U1 using Tapatalk
Old November 2nd, 2017, 17:51
themauler's Avatar
themauler themauler is offline
Re: Tucking the winch
Looks good. I chose 1/4" steel. If you don't like where you engagement handle is on the drum you might be able to clock it. Mine stays nice and tucked away out of harm. Probable sticks out in front of the grill 1"-2"
Nick Maul,
Just want to build something that won't break on the trail
Old November 3rd, 2017, 07:36
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Mine is done like that. ^
Old November 3rd, 2017, 09:51
jonb8's Avatar
I didn't go that route because I'm old and fat and didn't want to crawl under the jeep, to engage and freespool the winch.....LOL It's coming along....
Old November 3rd, 2017, 11:48
themauler's Avatar
Tucking the winch
Reaching the spool lever isnít any harder than reaching the hood latch in this case. Keep it up though. It took me a week or two of work to get it finished.
Nick Maul,
Old November 3rd, 2017, 16:02
jonb8's Avatar
Thanks, I'm hoping to get it done by the end of the weekend.
Old November 5th, 2017, 11:10
jonb8's Avatar
Old November 5th, 2017, 13:20
ftwelder's Avatar
ftwelder ftwelder is offline
I like the way you used the tube there, using it as a base for your shape.
endless jeep project that will eventually end up as a rust bucket in someones backyard.
Old November 6th, 2017, 10:20
jonb8's Avatar
I got the stinger on and the center notched and boxed for better winch access... Getting ready to pull it off for final welding......Hoot Hoot....
Old November 6th, 2017, 21:40
Greenz's Avatar
Greenz Greenz is online now
Very cool!
Old November 15th, 2017, 07:19
jonb8's Avatar
Finished it up and got it on, 19 bolts holding it on.... Now it's time to start on the long arms.
Old November 15th, 2017, 20:07
trippled trippled is offline
Nice job. Clean bumper that's not huge.
Old November 16th, 2017, 01:34
techno1154's Avatar
techno1154 techno1154 is offline
It all turn out lovely,...great lines, soft curves, non protruding, (park bench looking),..it certainly enhances the already great profile of the XJ.
Where are the relays?
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old November 16th, 2017, 02:53
jonb8's Avatar
The relay's will go were the coolant overflow jug is. I need to relocate it and build a mount.
Then hardwire the winch control inside to the switch panel.
WARN WINCH & AIR COMPRESSOR PowerPlant Dual Force HP 9500LB Winch NEW RWKHausSupply Vendor's Specials 0 June 13th, 2013 10:07
Tucking winch wiring Timber Modified Tech Discussion 4 October 2nd, 2008 16:52
M.O.R.E Front Winch Bumper + Ramsey REP8.5E Winch + Safari Snorkel mikeswrangler For Sale: Private Party Only. XJ ITEMS ONLY 1 July 24th, 2006 20:28
tucking your JKS QD's out of the way Kejtar Modified Tech Discussion 14 September 28th, 2004 04:55
Tucking the rock rails in Kejtar Modified Tech Discussion 2 July 2nd, 2004 06:28
