Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old October 31st, 2017, 13:43
sinat01's Avatar
sinat01 sinat01 is offline
Rust Repair/ body mods help
Ill try to upload pics when I get home but here is what im dealing with.
1999 2 Door Cherokee
built rock rails in place of the rocker panels.
I want to do the cut n fold, buut instead of folding whats left of the rusty metal. I want to cut it off and make a plate to go in there. Has anyone done this instead? and if so, how heavy of a steel did you use?
the other issue I have is the door hinge pins are worn (again) the bottom hinge is ovaled out, and I have the typical cracks around the vent in the door frame. I want to get the braces that weld in, and figure since im doing one, I might as well do the one to brace the hinges also.
Could I drill the ovaled out hole back to round, and size up a bronze bushing to go in the whole and use a bolt or pin to keep the door where it needs to be?
another rust repair rastein77 Modified Tech Discussion 11 February 23rd, 2014 10:01
Body shop for rust repair in NoVA? N8N_99xj South East Chapter 1 March 28th, 2013 11:47
Rust Repair. tcpoland Colorado Chapter 0 April 7th, 2012 14:14
Rust repair... DutchVDub Colorado Chapter 6 May 29th, 2008 20:57
95-xj-rust repair 95xjpa OEM Tech Discussion 3 March 29th, 2005 07:18
