Old October 31st, 2017, 10:45
csailors csailors is offline
Dana 30 truss vs sleeve
Im looking to strengthen my Dana 30 when i re gear. Those that have done either or give me your opinions.
I am leaning towards the inner tube sleeves due to clearance and track bar mount but i think ill have to remove the knuckles to do this?
Do you sleeve the short side also or just the long?
Running 35s now and just doing it for a little insurance. Dont get crazy with the throttle, just slow speed stuff and crawling.
Old October 31st, 2017, 11:31
RCP Phx RCP Phx is offline
Re: Dana 30 truss vs sleeve
You'll get way more benefits from a good truss, sleeving does nothing to strengthen the housing!
Old October 31st, 2017, 12:27
sinat01's Avatar
sinat01 sinat01 is offline
honestly, just do both. more strength all around
Old October 31st, 2017, 12:40
VAhasnoWAVES VAhasnoWAVES is offline
the greater advantage comes from trussing.
what clearance issues do you think youll have?
Old October 31st, 2017, 12:44
denverd1's Avatar
denverd1 denverd1 is offline
did sleeves when I put in front locker. cheap insurance and I had it apart anyway. did both sides.
Old October 31st, 2017, 13:06
Oil pan clearance in the center. maybe track bar axle mount
To sleeve the housing makes its more rigid from bending. Which is what I am looking for. The defiantly strengthens the tube. If you are referring to the center section that is not my concern as it is not the weak point. Just the carrier deflection inside is. Weight is also an issue.
Old October 31st, 2017, 13:22
cwyman6 cwyman6 is offline
Sleeving is a waste of time. The housing just breaks where the sleeve stops. Seen 2 of them break in the same spot.
Old October 31st, 2017, 13:45
you are taking one (perceived) failure mode and moving it to another point. by making the tube more rigid, you are moving the weak point to the housing, which is already vulnerable... watching people huck jeeps at the dunes, the failures ive seen most often are bent Cs (not the tube itself) and cracked housings. sleeves will not address this. trussing is a better option.
the housing and center section deflect together. they are not independent of one another. reducing housing deflection, reduces carrier deflection, which reduces ring gear deflection, a big cause of ring gear failures. a full carrier replacement (full case locker) and stout diff cover also help combat ring gear deflection.
artec makes a great budget minded truss. having seen it in person, clearance is not an issue. having ran a trussed (larger) axle, clearance is not an issue. and that was with high steer and a raised track bar mount. proper bump stopping goes a long way.
Old October 31st, 2017, 14:30
That makes a valid point. I never had the need for neither option before but mvong up in tire size I’d like to get a little strength back in the front. Don’t know what to do if anything on the rear now.
I’ll take a look at the truss. I just setup my bumpstops now for the 35s on 3” lift so I’m set for clearance now.
I checked out the truss. Def have to modify that to work with my track bar axle mount.
Old October 31st, 2017, 14:43
srb531 srb531 is offline
i did the 3 step . sleeve, truss, gussets...........
Old October 31st, 2017, 15:10
C gussets tire into the truss? Got any pictures?
Old October 31st, 2017, 16:38
If you were to make your own, the gussets can be part of the truss!
Old October 31st, 2017, 17:55
I’ll have to make my own anyway due to my track bar mount. I’ll just make the c gussets and may as well truss the rear while I’m at it.
Rear axle is bent forward 1/4” on the drivers side. Need to try to bend it back before the truss goes on. Winch and a tree??
Old October 31st, 2017, 20:53
TRCM's Avatar
TRCM TRCM is offline
Doubt that would work....if you pull it with the winch, the suspension will just let the whole thing move....need to get it out of the vehicle and on a press or alignment table/plate to straighten it....somehow you need to keep the straight part from moving while you bend the bent part back in line.
Old October 31st, 2017, 21:33
x 1000
Dana 30 Build: Sleeve, Truss etc.... for 35's nosigma Modified Tech Discussion 208 February 26th, 2017 09:43
Dana 35 for 37's: Truss, Sleeve & Super 35 Kit? nosigma Modified Tech Discussion 31 October 31st, 2014 19:29
Who in So Cal can sleeve, truss, and gusset a D30? Nimrod SoCal Chapter 9 September 23rd, 2014 22:24
Dana 30 Crush Sleeve? brifro123 Modified Tech Discussion 11 October 16th, 2007 04:54
Dana 30 use a crush sleeve? bretto OEM Tech Discussion 7 January 2nd, 2005 11:44
