Old October 30th, 2017, 07:09
JaCKaL6996 JaCKaL6996 is offline
New LCA mounts
Ive installed new gears and a locker...in the process of welding the truss in place now. Im gonna be doing LCA mounts next. Since the axle is out of the vehicle, i was wondering if anyone had any tricks they used to locate the mounts in the correct position. Im a little nervous about cutting off the old ones without complete confidence in making sure ive got a sure fire plan in place for locating the new ones. Thanks in advance guys.
Old October 30th, 2017, 11:47
kev4dez kev4dez is offline
Re: New LCA mounts
Look at Artec LCA mounts. They are made to index off of the stock spring perches. I have put two sets of these on and they are beefy and easy to install.
Kevin
Old October 30th, 2017, 12:14
VAhasnoWAVES VAhasnoWAVES is offline
Re: New LCA mounts
if your current control arm brackets are strait, consider just adding mini skids to them. much less work, and sufficient for most people.
if they are tweaked, see the above recommendation.
For those with iron man mounts or brown dog mounts question inside... Demolition_x Modified Tech Discussion 21 July 26th, 2011 22:55
Wilderness rack with XJ rail mounts, light, & highlift mounts Roxtar MWC For Sale/Wanted Forum 0 May 19th, 2011 16:24
Wilderness rack with OEM rail mounts, light, & highlift mounts Roxtar MWC For Sale/Wanted Forum 9 June 28th, 2010 06:23
Drop mounts for front control arm mounts jcianci Modified Tech Discussion 13 November 15th, 2007 09:04
