Old October 29th, 2017, 11:53
Sullie Sullie is offline
88 xj front tire rubbing
As the title says I own an 88 xj, the front tires are rubbing the coils when I turn.
Any advice on how to fix?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old October 29th, 2017, 11:59
Sorry ment to add these pics too
Old October 29th, 2017, 13:57
RCP Phx RCP Phx is online now
Re: 88 xj front tire rubbing
First start with some control arms and maybe even DB's since your lift seems like a lot. You also need a adjustable trackbar to center your axle. It also looks like somebody "fubar'ed" your spring mounts! They don't even look like proper fitting springs!
Old October 29th, 2017, 14:58
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Uh.....all I can think of is, "where in the South...?"
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
Old October 29th, 2017, 16:37
Correct me if im wrong, but it looks like the previous owner welded a plate on the bump stop to give it a lift, is that what it looks oike to you guys?
If this is the case ill go to pullapart and get new ones to put a proper budget lift.
First two pics are found online
Old October 29th, 2017, 17:19
Bent's Avatar
Agree, lose the custom lift plates.
Old October 29th, 2017, 17:53
I would assume best way is to grind off, im sure the bumpstop rod is welded on top, correct?
Looks like one rod is leaning forward, what would be the best way to get it straight again, beating it?
Old October 29th, 2017, 20:55
Jeep Driver Jeep Driver is offline
Hilarious.
Old October 29th, 2017, 22:42
Originally Posted by Jeep Driver View Post
Hilarious.
Actual replys would be nice,
Old October 30th, 2017, 07:26
Bent's Avatar
IIRC correctly the earlier models were threaded on. From what I can see they look to have been sleeved. Without pics of what the previous owner may have done up top being threaded may be a mute point, though.
If it were me the first thing I would go at would be getting rid of it and going back to the OEM setup.
Old October 31st, 2017, 14:16
Does it look like its sleeved to you guys?
Old October 31st, 2017, 14:57
I'd still like to know how it's possinbly rubbing with that amount of wheel offset? What size tires/wheels are those?
Old November 1st, 2017, 19:30
33x12.50R15LT
Old November 1st, 2017, 21:20
I'd still like to know how it's possinbly rubbing with that amount of wheel offset? What wheels are those?
Old November 1st, 2017, 21:43
33x12.50R15LT
tire rubbing jonesy72 Modified Tech Discussion 5 July 12th, 2009 17:47
Replacement LCA's - tire rubbing fix? mfascuba Modified Tech Discussion 5 June 3rd, 2008 00:17
tire rubbing snorkel The glory wagon Modified Tech Discussion 2 October 26th, 2006 23:45
Tire sizes w/o rubbing gradon Modified Tech Discussion 6 October 23rd, 2006 10:43
Left tire rubbing LCA. Tips? OT Modified Tech Discussion 4 January 28th, 2004 20:35
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
