Old October 27th, 2017, 23:03
coldcdn coldcdn is offline
novak shift linkage =dissapiontment
so I decided to do away with the stock and huge pain in the a$$ transfere case shifter. I was actually looking forward to the install all straight forward no hassle and get it done sort of job and from what I heard would end up with a great result. Well that was not the case had to get it shipped to Canada so that sucked the price kinda sucked to exchange and customs ect but whatever as long as it worked, well it didn't. the mounts install great no issue there at all the problem is that the cable will not engage 4low which is kinda of a big deal. its a np242j evenm when adjusted fully towards tcase is still about a 1/2 inch short of cable anyone else run into this? I know I can make it work but for the money I paid really figure I shouldn't have to so yep dissapiontment
Old October 28th, 2017, 04:11
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: novak shift linkage =dissapiontment
My head hurts when I read that with no punctuation.
Old October 28th, 2017, 04:23
md21722 md21722 is offline
x 2.
Old October 28th, 2017, 04:25
cruiser54's Avatar
Thanks for your post. Please understand that we’re here to help and we enjoy our Jeeps as much as anyone else.
That said, also be aware that we need good solid info on your Jeep so we can provide the most accurate info to you without wasting any more of your time or money in getting to the root of your Jeep’s problem.
Also, please be aware that during an open thread/survey here on Cherokee Forum it was found many members, both new and seasoned, will skip over posts that prove difficult to read. Those kinds of posts include run-on sentences and little or no punctuation.
Please keep these things in mind as you post so that you can reap the most benefit from this forum.
Old October 28th, 2017, 06:14
srb531 srb531 is offline
had the same problem installing the novak cable on my 98 w/ a 242, would not engage low range. i had to cut a little half round notch in the bezel & tunnel so lever could come back a extra 3/4 " to fully engage 4 low, it was a pia install. yet recently removed the 424 & put in a 241 rubicon tc & the shifter worked perfectly lever indexed correctly w/ the new bezel. it must have something to do w/ the fulltime mode position making the whole travel distance longer then w/ a non fulltime case ?
Old October 28th, 2017, 07:21
RCP Phx RCP Phx is offline
I've owned 5 XJ's and never had a issue with the t-case shifter???
Old October 28th, 2017, 08:03
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Neither have I but I have a Bosstwerks kit sitting on the shelf for the next time I pull the t case or have to work in that area. That whole z bar thing is stupid and over complicated.
Old October 28th, 2017, 08:12
Jeep Driver Jeep Driver is offline
No problem with my Novak.
Stock version sucks.
Old October 28th, 2017, 12:52
PhotoJared's Avatar
PhotoJared PhotoJared is offline
I love my Novak shifter.
Worked perfectly with my LS swap and NP231. Didnt need to worry about fabbing a long linkage.
Old October 28th, 2017, 15:39
Really wanted it to be a simple install, but that inst the case not to sure why everything is stock. It's a 242j mated to a aw4 and no modification to mounting points so wtf?. Left a msg will hopefully here from them on Monday
Old October 29th, 2017, 06:43
i called them and spoke w/ a tech when i had the problem, they told me to put tc in 4 low position, put shift lever in 4 low position & hook up cable w/ both adjustment points in the middle of there travel range. when i did that it would not go up into 2 hi . i adjusted it every which way i could, they told me i could return it if i wasnt happy w/ it, not at this point in the pia install . i made it work as i mentioned before.too bad for me the boostwerks unit wasnt being sold yet.
Old October 29th, 2017, 09:38
DirtyMJ's Avatar
DirtyMJ DirtyMJ is offline
Both the Boostwerks and Novak shifters are total overpriced garbage and if they work satisfactory it is merely by chance.
Edit, Novak products in general tend to leave a lot to be desired.
Old October 29th, 2017, 10:29
PhotoJared's Avatar
What the hell are you talking about? How is the boostwerks linkage over priced? Its $36. Feel free to develop, market, fabricate, and sell something like that for $36 while still making a profit margin.
I've had both the Boostwerks and Novak linkage and they both work as intended (they shift a transfer case).
I also have multiple Novak products. Each one of them were developed for their specific application and work as intended. While there are some gripes i have regarding some of the novak products (headers could be cleaned up, motor mounts could be developed a bit better) but they're fine.
Old October 29th, 2017, 10:35
Envious.
Old October 29th, 2017, 10:46
DirtyMJ's Avatar
The Boostwerks linkage for a manual trans was designed wrong, with the wrong throw ratios, and would hit everything in sight and likely never work. Maybe they fixed it, but the mistake was so rooky that it was laughable at best, and clearly demonstrated that they had no actual understanding of what they were doing. Mine uses half the parts, and actually works, and would cost the typical person something in the $13 range (it cost me nothing but time as I sourced the rod ends and hardware from an incident involved aircraft).
No cable shifter setup has ever been fully reliable when exposed to severe usage over a long period of time, including OEM setups, and it is an absolutely unneeded complication when every tcase setup ever built could be shifted reliably with a rod/pivot linkage providing you had half a brain to figure out how.
Novak LS motor mounts use some hack**** carriage bolts and a pancake bushing. The last time I used a carriage bolt was to assemble a deck, and even at that I felt dirty doing it. Read through their tech and the bias that is inherent in it, and you'll see that they have no actual creativity, they simply are long established and therefore have a large (but flawed) product lineup and a 'trusted' name and thus are able to maintain market share. Many of their basic adapters are flawed in that they will not adequately seal, or do not offer clocking when they're a multi-piece design, or have been designed to be much longer than needed.
When I pay good money for something, I expect it to be top notch. Novak is not. Boostwerks is not. Their products will not be seen on any of my builds on that basis.
Novak T-Case linkage, anyone running it? PocketsEmpty Modified Tech Discussion 4 February 8th, 2013 13:43
Novak 231 shifter and linkage RoyalXJ NAC Classifieds 0 January 7th, 2012 06:39
NP 231, AA SYE, Novak Linkage live24wheel Arizona For Sale/Wanted 14 February 14th, 2011 15:36
NOVAK ADAPTERS NP 231 shifter/linkage/knob XJpoopbrown NAC Classifieds 4 May 27th, 2010 18:16
Help bending Novak Tcase Shift Rod aszaunmi Arizona Chapter 0 February 8th, 2007 08:04
