Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old October 25th, 2017, 08:29
chickenbot chickenbot is offline
Bed liner paint
I'm trying to find a bed liner paint that is a desert sand with a flat sheen. I prefer it to be a roll on. Any companies they yall suggest?
Old October 25th, 2017, 13:59
smokeyyank's Avatar
smokeyyank smokeyyank is offline
XJholic
Re: Bed liner paint
Monstaliner will be your best bet for job but may not be able to find a flat finish. To do that you'd probably have to spray paint over the bedliner.
Old October 26th, 2017, 07:09
Re: Bed liner paint
I'm waiting on a sample from https://www.durabakdepot.com/durabak18.php hopefully it'll work
Old October 26th, 2017, 07:51
Heavyopp Heavyopp is offline
Re: Bed liner paint
get a sample from monstaliner too -- I do have a sample of their color desert sand -- it's pretty flat as in not shiny -- it does have a texture when applied which can be minimized with a roller
Old October 26th, 2017, 13:00
Re: Bed liner paint
Can Monstaliner be applied smooth or does it have to have a texture?
Old October 26th, 2017, 13:11
smokeyyank's Avatar
XJholic
Re: Bed liner paint
Pretty sure all bedliners will always have a texture, if you want smooth you're going to have to shoot paint.
Old October 26th, 2017, 14:23
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Re: Bed liner paint
It has to be thinned out a lot. Here a is a how to
http://www.magnetpaints.com/Monstali...ed-brushed.htm
Old November 3rd, 2017, 12:43
Re: Bed liner paint
can you sand monstaliner to make it flat in sheen and appearance?
Old November 9th, 2017, 10:21
smokeyyank's Avatar
XJholic
Re: Bed liner paint
I guess but seems like a lot of work for little benefit. If you sand it you'll still have to spray something on top to make it smooth. Honestly just plastidip or shot paint it if you want the flat/matte look.
Old December 5th, 2017, 10:23
burntkat burntkat is offline
NAXJA Member #1145
Re: Bed liner paint
Incorrect. Durabak is available smooth.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old December 7th, 2017, 09:22
smokeyyank's Avatar
XJholic
Re: Bed liner paint
Good to know. Never heard of that stuff
Old December 7th, 2017, 11:21
indian's Avatar
indian indian is offline
Re: Bed liner paint
with raptor bedliner from U-pol you can choose any color from RAL catalog
my xj:
Old February 21st, 2018, 12:55
Re: Bed liner paint
Anyone ever heard of Al's Liner?
Old February 24th, 2018, 12:12
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Re: Bed liner paint
Al's as in NAPA's brand? Never used the bed liner but their undercoating is better than 3M's.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Bed liner paint jobs Sub Zero Paint and Bodywork forum 3 March 6th, 2016 18:18
Traditional Paint or Hard Liner? Jhumphrey Paint and Bodywork forum 10 January 22nd, 2014 18:35
Bed-liner as paint for jeep? 1bad93z Modified Tech Discussion 15 February 6th, 2009 09:11
bed liner paint job on the XJ ThE HiV Modified Tech Discussion 7 June 15th, 2008 08:11
Possable to Paint head liner? XJ Samo OEM Tech Discussion 9 June 21st, 2007 15:58
