Old October 17th, 2017, 13:43
jrowell's Avatar
jrowell jrowell is offline
New Engine + New Motor Mounts = #$&@ at 1000RPM
Dropped a new engine in my 87 along with aftermarket Motor Mounts. I only have about 1 mile on it so for, but noticed there is SIGNIFICANT vibes between 800-1200 RPM's. Before and after those rpm's the vibes are only slightly more than the stock engine/motor mounts. The vibes happen driving and in park. Could the vibes point to any other problems? or is it just a quirk of my new setup?
Old October 17th, 2017, 13:50
sinat01's Avatar
sinat01 sinat01 is offline
Re: New Engine + New Motor Mounts = #$&@ at 1000RPM
what motor mounts? good rubber mounts will transmit more vibrations for a while. especially new. poly ones are even worse. My ironman4x4fab motor mounts vibrated pretty bad when I first put em in, but they arnt bad at all now.
Old October 17th, 2017, 17:07
jrowell's Avatar
they are a poly blend. They vibes are only slightly more than stock through all the other rpms... very acceptable. At 1k rpm feels like a vibrating massage chair on overdrive!
Sent from my SM-G930V using Tapatalk
Old October 17th, 2017, 17:19
jrowell's Avatar
I'm betting that the rpms are just resonating in that area. I'm told as I put more miles on them it'll calm down. I'm not worried about the vibes so much as me doing something wrong on the engine install.
Old October 17th, 2017, 17:28
sinat01's Avatar
mine vibrated at idle and when letting the clutch out for the first couple thousand miles, and they are rubber, poly might take longer to wear in
Old October 17th, 2017, 18:50
csailors csailors is offline
I have brown dog poly mounts and I stared out with the through bolts too tight. It vibrated awful.
Loosen the through bolts a little on each side and test drive until the vibration is gone. I’d bet you tightened the though bolt and nut tight.
Old October 17th, 2017, 18:59
kcox506's Avatar
kcox506 kcox506 is offline
I understand vibes are annoying to most but thats what torque transfer feels like
Ironman4x4fab Marketing Manager
2000 XJ ~4.5" '06 4.0
LP44 w/Rubi Air Locker & 8.8 ARB
231 w/ beefy stuff
Old October 17th, 2017, 20:29
Jeep Driver Jeep Driver is offline
Make your own, far better off.
Old October 17th, 2017, 20:34
jrowell's Avatar
Make my own what?
Old October 17th, 2017, 20:39
Make my own what?
Stock replacements suck and brown dogs suck.
Old October 17th, 2017, 20:50
jrowell's Avatar
I agree, that's why I didn't go with either of those.
Old October 17th, 2017, 21:12
I have 0 vibes at any rpm and 0 torque roll.
Inserts can be found at NAPA..........well over 100 different designs.
Old October 17th, 2017, 21:21
kcox506's Avatar
Is the bushing housing only tacked to the mount as shown on both sides?
231 w/ beefy stuff
Old October 17th, 2017, 21:31
It's captured, I used a press to compress the outer band before I welded it. It ain't going anywhere.
3" OD IIRC.............same insert sized used in hundreds of makes and models. Mine was for a Toyota Camry.
You could go to the PnP and get a couple of mounts to cut the bracketry off and use the press ring.....whatever you want to do.
You can also drill and fill with weld in the center of the band or you can drill and tap for a short bolt (2) and thread two button heads through the band into the insert thus mechanically combining the two.
however you want to design it.
Old October 17th, 2017, 21:34
Motor Mounts and Engine Plates by SFR StinkyFab Vendor Advertisements 29 August 30th, 2016 10:02
What's broken? Motor mounts, engine bracket? Teufel Hunden Modified Tech Discussion 11 December 14th, 2014 18:34
10% Off - Brown Dog Motor Mounts & Engine Brackets Brown Dog Vendor's Specials 24 December 29th, 2011 11:43
Brown Dog Motor Mounts 2.5 engine PhotographerMike SoCal For Sale 4 May 26th, 2009 17:22
Engine(motor Mounts) Questions??HELP cbert1234 OEM Tech Discussion 1 September 15th, 2004 20:11
