Old October 5th, 2017, 11:15
burntkat burntkat is offline
NAXJA Member #1145
Clockspring- Non-Cruise versus Cruise equipped
Folks-
Vehicle is my son's 97. While replacing the steering box I was dumb enough to turn the wheel. In doing so the clock spring was destroyed.
Now Cruise and horn do not work.
I looked up the part for replacement and all I can find is a non-cruise equipped part. Anyone know where I might obtain a clock spring for a 97 with cruise?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 5th, 2017, 15:42
Tim_MN's Avatar
Tim_MN Tim_MN is online now
Freakish Hand Strength
Re: Clockspring- Non-Cruise versus Cruise equipped
I have had very good results with used clock spring assemblies. The airbag system is self testing, so any faulty parts will be immediately discovered. I have read, but cannot prove, that the TJ Wrangle and the XJ Cherokee use the same clock spring assemblies.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old October 5th, 2017, 18:27
NAXJA Member #1145
I suppose I will get a TJ similar year clockspring through Amazon and if it isn't right I will send it back.
Old October 6th, 2017, 11:24
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
The cruise control units are pricey. After my act of stupidity bleeding the power steering I was lucky enough to find one at a P&P.
If you end up with a used one make sure (that it is centered) to center it and your steering wheel before installing.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
Wtb 99-01 clockspring w/cruise 831_xj Sierra Chapter For Sale 1 January 5th, 2014 09:58
97-01 airbag clockspring with cruise DeftwillP Wanted: Private Party Only 1 September 21st, 2012 14:34
Adding Cruise Control to a non-CC equipped XJ? xL8 APEKSx Modified Tech Discussion 5 March 31st, 2009 22:51
Wanted: Clockspring for cruise 97-01 MisterFubar MWC For Sale/Wanted Forum 3 July 15th, 2008 12:33
WTB: 97+XJ clockspring (with cruise control) johnlv6 Wanted: Private Party Only 0 June 19th, 2006 13:13
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
