Old October 2nd, 2017, 08:17
tchase tchase is offline
Early XJ brake flex line???
So the new (to me) Jeep needs a front flex line. None of my parts suppliers list stock for an '85. Anyone know what the difference was on the early ones? They have stock for a '90 (which I have on it's way), which uses the same caliper.
Anyone know any reason why a line for a '90 won't work on an '85?
Old October 2nd, 2017, 08:53
burntkat burntkat is offline
NAXJA Member #1145
Re: Early XJ brake flex line???
Check the thread-pitch and banjo end bolt size. Crossref to another vehicle and go from there.
Failing that, buy a set of afterarket lines. There's a guy on P4X4 that makes them to spec.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 2nd, 2017, 08:55
NAXJA Member #1145
Here's what you need, looks like. They're out there, now you just need to figure out how to get them in Canuckistan...
https://www.oreillyauto.com/shop/bra...039=Show%20All
Old October 2nd, 2017, 09:52
Canuckistan. lol
Thanks, I can get one out of montreal but that's 3 days to ship.
I have the '90 one in my hand just trying to figure out if it will work. Looks like the bend at the end is different but the fitting size seems to be the same.
Old October 2nd, 2017, 10:31
NAXJA Member #1145
I think YJ lines are a direct cross as well. Different shape, but they fit properly and do the job.
Please don't be one of these idiots I see on forums now and again that tries to screw a 3/8 line into a 10mm thread. Yes, they appear to fit, but they do not seal. It's literally a life safety issue, don't skimp. "Close enough", ain't!
Old October 2nd, 2017, 17:13
Yeah thanks. No worries both lines are 3/8". Trouble I'm having now is I can't get a banjo bolt. Got a caliper and a flex line but can't find the bolt anywhere.
Old October 3rd, 2017, 07:09
NAXJA Member #1145
I don't know what you guys have up there in the Great White North, but I had a similar problem on a bike. Kawasaki uses 10mm banjo bolts with a peculiar threadpitch.
I was able to find the parts through Grainger and McMaster-Carr.
Popped a brake line now brake light wont go out? nicpaige OEM Tech Discussion 5 August 6th, 2016 07:55
FS: Russel Performance Stainless ARB Line Kit and Brake Line Fittings Mike L SoCal For Sale 6 June 16th, 2011 10:28
Early Knuckle brake mod jamiemac Modified Tech Discussion 17 August 31st, 2009 13:17
Brake pedal for early 90's XJ - NON-ABS!!! gone postal Wanted: Private Party Only 2 February 19th, 2007 14:53
rear brake line extensionsand emer. brake??? grand94jeepxj Modified Tech Discussion 6 April 5th, 2005 16:24
