Old September 27th, 2017, 22:45
PavementPrincess PavementPrincess is offline
Auto to manual swap parts
I've swapped from the aw4 to manual trans in my 2001 Cherokee. If using the factory console aside from the shift boot is there anything else I'll need to put it all together? I know on the older cherokees you needed a trim piece. Just curious about people who have already done the swap.
Old September 28th, 2017, 19:10
JeepNoob JeepNoob is offline
Re: Auto to manual swap parts
Thought there was some clips/screws for the shifter boot... I dunno, my '96 never had them. I know for a fact that I did have a second rubber boot/cover that was secured to the transmission tunnel with some sheet metal screws.
Old September 28th, 2017, 20:10
lawsoncl lawsoncl is offline
The 2001 engine computer might throw a code if it doesn't see the trans computer. You'll need to do something about the neutral/park switch so you can start it. I don't recall offhand, but I think the NSS grounded the wire from the starter relay.
You'll obviously need all the clutch stuff, rip put the key interlock wiring and solenoid, etc.
Old October 1st, 2017, 15:56
Ithe swap is done and running. I'm just curious of those who have the 2nd gen xj's aside from the shift boot is there a trim piece for the console. I still have the automatic console in it. What parts do I need for oem look
Old October 3rd, 2017, 20:00
Anybody?.....
Old October 3rd, 2017, 20:40
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
The OEM manual shift boot should come with a "rigid" base, that snaps in place into the center console. The rigid base is comparable to your stock Automatic Gate, snap in trim piece...
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old October 3rd, 2017, 20:46
I see the piece listed for the 1st gen xj but not for the 2nd. All I see is the boot
Manual to auto swap, manual control, what´s needed luischia Modified Tech Discussion 4 July 29th, 2015 08:03
86 xj Auto to manual swap Project-Goldi-lock Modified Tech Discussion 1 May 7th, 2012 09:28
Auto to manual Swap quake82 Modified Tech Discussion 5 June 2nd, 2009 22:20
Manual to Auto swap help... 89cherokee89 Modified Tech Discussion 0 March 31st, 2008 20:44
auto to manual swap... langer1 OEM Tech Discussion 4 August 19th, 2005 09:11
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
