Old September 27th, 2017, 19:07
chrisjeep chrisjeep is offline
hard start/low idle after TB/TPS/IAC sensor cleaning
I cleaned the TPS/TB/IAC and now I have a rough start , low idle and a slight miss.
I changed the fuel pump(bosch),was getting 25-30 psi before the change and the same after change. I installed a check valve near the tank, no change. changed plugs. I hate throwing part at issues, can someone tell me the order in which I should go about fixing this. it's a 1994, 4.0 .
Old September 28th, 2017, 05:56
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: hard start/low idle after TB/TPS/IAC sensor cleaning
Injectors stock? They could be bleeding down pressure
Old September 28th, 2017, 06:39
cruiser54's Avatar
cruiser54 cruiser54 is offline
That fuel pressure is loooow.
Old September 28th, 2017, 20:27
stock injectors. fuel pressure on gauge goes right to zero when engine is turned off. would like to know what series of test I can do instead of throwing parts at it.
Old September 29th, 2017, 06:19
cruiser54's Avatar
What happens if you pinch the fuel return line with the pressure gauge on it?
Replacing those injectors with the Volvo 746s is never a bad idea. Under $100
https://www.cherokeeforum.com/f72/78...ectors-222140/
Old September 30th, 2017, 07:44
going to do the injector swap, keep you guys posted. thanks for the help
Old October 1st, 2017, 18:02
lawsoncl lawsoncl is offline
Bad fuel pressure regulator?
Old October 1st, 2017, 19:49
try priming the injector first by turning the key to on a few times, but dont start it until the 4th or 5th time. if it stumbles starting the injectors may be leaking and the engine is clearing its self because its flooded.
however if it fires right up instead, the fuel pressure regulator isnt a bad bet, its starving/ hard starting until fuels getting pumped to the injectors.
Old October 4th, 2017, 20:06
old_man's Avatar
old_man old_man is offline
Throttle position sensors do not respond well to cleaning and routinely fail afterwards.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old October 4th, 2017, 21:37
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
The fuel pressure shouldn't bleed down nearly that fast.
When you replaced the fuel pump, did you check the upper
section for cracks? The hose tends to crack near the clamp
and will release pressure back into the tank.
Old October 4th, 2017, 21:54
old_man's Avatar
X2
Loveland, Colorado
Old October 4th, 2017, 22:22
trippled trippled is offline
X3, however usually new fuel pumps include that piece of hose as long as it was used. I would say you have a failing regulator. If it was an injector bleeding of 10psi running it would probably hydrolock the motor or have a lot of black smoke. Pinch the return line momentarily and see if the pressure comes up.
Hard to start, no idle Makapo OEM Tech Discussion 3 February 1st, 2015 20:26
hard start and slow idle in the mornings hightime81 OEM Tech Discussion 2 August 4th, 2009 18:53
Hard start, lopey idle xj2win OEM Tech Discussion 3 April 6th, 2009 19:14
Hard Start/Non-Idle XpedientJ OEM Tech Discussion 1 December 31st, 2007 21:20
Rough Idle, Hard Start logdog OEM Tech Discussion 3 April 16th, 2004 18:58
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
