Old September 25th, 2017, 14:09
bradleyheathhays bradleyheathhays is offline
2 XJ questions and an identify this picture contest
1) Are the front and rear leaf spring bushings on a '96 XJ the same part?
2) My front sway bar measures 1.014 in or 25.75mm diameter. The bushings that attach it to the frame (on rockauto) are sold in 23, 24, 26, and 26.5 mm sizes. I would be looking for the 26mm?
3) and finally..what are these to...?
Picked up a front windshield along with these two that's really narrow left to right and is curved back on the bottom outside corners resembling something like a '63 Chevy C10. Have no clue what they're to, or if the windshield and grill parts even go together.
Old September 25th, 2017, 15:58
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: 2 XJ questions and an identify this picture contest
Front and rear leaf spring bushings are very different in diameter. Moog SB371 for the front and SB372 for the rear. I believe SB372 for the shackles too.
Not sure on the sway bar bushings.
Those pieces are for a Nash Metropolitan. We will see if this image shows. If not, just do a google image search for a Nash Metropolitan grill.
Old September 25th, 2017, 20:50
Yep no doubt...Nash Metro. Wonder what they'd be worth?
Old September 26th, 2017, 23:04
I might try to put them up on the wall.
Any suggestion how to clean these up?
Old September 27th, 2017, 12:24
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Other than perhaps a quick going-over with soap and water to knock off any dust/grease, I'd leave them alone - the sort of folks who'd be looking for something like those will probably be real picky about repair/reconditioning of them, I'd think.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old September 27th, 2017, 14:49
Anak's Avatar
Mostly Harmless
Well, they are not NOS condition, that's for sure.
I am guessing they are chrome plated, and if anyone were to want to use them in a restoration they would probably have them re-chromed.
It probably would not hurt to spray them with a mild acid to clean off the surface rust, rinse them off and buff them with a clean terry cloth towel. Experiment in an area on the worst of the two and see how it goes.
If you make them look nice and hang them up in your garage that will probably do the most to keep them in decent shape.
Old October 3rd, 2017, 11:29
Thanks for the cleanup advice.
Looks like I also have the rear windshield as well. Wonder what it's worth or where I'd go on the net to find out?
NAXJA Colorado Fest Flyer Picture "Contest"! freerider15 Colorado Chapter 37 May 21st, 2015 23:12
2015 NACFEST T-Shirt Picture Contest XJLI North Atlantic Chapter 5 April 14th, 2015 18:01
Naxja Arizona Chapter T-shirt Picture Contest YEAGS Arizona Chapter 20 February 28th, 2011 19:30
Picture Contest, vote for JR! WheelinJR NorthWest Chapter 4 January 6th, 2010 22:49
T-shirt Picture Contest winners Goatman 25th Anniversary Celebration! Moab, Utah 6 October 3rd, 2008 19:22
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
