D44 hd in xj
Blarin.aaron
Texas
So First off....I just wanna say you guys are awesome! I've been building my jeep for like 2 years and I use info from here all of the time!! So thank you!
Now to the point.....I have a 96 4cylinder 5 speed 2 door 2wd I'm converting...
I bought the axles from a 78 f150 super cab regeared to 5.40s with spools
The 9 inch is already under the back of the jeep....I just ordered the xj/tj combo brackets from ballistic fab....they came with no instructions at all....any info/help I could get putting them on my axle would be amazing!
The axle has 3 inch tubes its 3 inches wider than stock and it has no brackets on it anymore. I need to figure out pinion angle and locate where to put all of my brackets....can you guys help me?
Concur.
Do be aware that you might need to do a cut/turn of the inner Cs to get the caster angle and the pinion angle to fit your application.
