Old September 19th, 2017, 01:26
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
How far forward can you stretch adjustable lca/uca without body/mounting mods
How far can one stretch the stock axle and mounts with adjustable lca/ uca. The goal would be centering bigger tires more forward in the wheel well
Old September 19th, 2017, 18:01
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: How far forward can you stretch adjustable lca/uca without body/mounting mods
About 1". 2-2.5 if you move the frame side trackbar mount too.
Old September 19th, 2017, 18:26
Francesco Francesco is offline
Problem with that is when the wheels are at full stuff, the axle is moved forwards a bit due to the angle of the control arms at ride height, which would make the tires rub on the front hump in the wheel well, although it would look more natural at ride height. It's a trade off.
AW4 Valve Body Mods Robahr24 Jeep Street and Performance 20 January 23rd, 2009 19:27
Need pics of body mods (chops) Gator Non-Tech / Off Topic 8 March 26th, 2006 17:39
Body Mods Skeletoil OEM Tech Discussion 4 August 17th, 2004 09:06
body mods DARKFLY Modified Tech Discussion 2 October 23rd, 2003 05:58
Body mods for rockers and which welder? csudman Modified Tech Discussion 2 June 30th, 2003 09:04
