Old September 17th, 2017, 00:39
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
proper shackle options for RE 3.5 lift
hey all,
Ive added gears, locker and 33s to the jeep this summer. its a 99 auto running an RE 3.5 superflex arms, which i need to look into replacing but thats another issue.
ive been running my set up for a while and this summer i have it bump stopped well, though it needs some tuning for flex and the rear leafs are recently new again. so, i currently have the iron rock shackle, but the angle isnt what it should be and im wanting to tune this for ride quality and flex.
when the jeep becomes a tirpod i can feel where she needs more flex and traction, its close to what i need , but still has some fun teeter action and looses grip when flex is maxed out, even with the rear locker.
What im asking in particular is what set up is everyone else running with these leaf springs?
my rear DS is stock, if there is a bolt on shackle set up for 45 shackle angle ( i hope), ide be interested in looking into that. i dont want to lift it anymore if i dont have to. COG is very good as is.
Old September 17th, 2017, 03:12
smallredxj smallredxj is offline
Re: proper shackle options for RE 3.5 lift
Before I swapped to OME leafs I used re 3.5s. They were fairly clapped out (I got them used for free) and only netted about 2 inches of lift. I ran then with HD engineering standard shackle relocation brackets and Comanche shackles that I later swapped to rustys .75in lift shackles. In total I sat around 3.5-4 inches lift and it road/ flexed great, although I'm glad I swapped to OME. I'd say if you want more flex then get some shackle relocation brackets. If not shackle angle then maybe driveshaft is limiting? I also run stock ds so idk.
proper torq for a RE 5.5" long arm lift? 90Pioneer Modified Tech Discussion 2 November 16th, 2010 13:39
A proper non-budget 2" lift? JWFokker Modified Tech Discussion 8 March 23rd, 2010 23:39
What else do I need for a proper lift? 96cherokeenewb Modified Tech Discussion 21 February 9th, 2009 12:26
Proper caster angle for 6.5" lift? emr1101 Modified Tech Discussion 5 October 12th, 2008 14:09
1" lift shackle bad shackle angle? mitsumotors Modified Tech Discussion 1 April 21st, 2008 21:16
