Old September 12th, 2017, 19:19
Jeff-97XJ's Avatar
Jeff-97XJ Jeff-97XJ is offline
Battery opinions
I have been using Optima Red Top batteries since around 2000. I put one in then and it lasted 7 years. I put one in 2007 and it lasted 7 years. I put one in 2014 and after just 3 years and a few months, it needs replacing.
I Need Advice.
I used to love these batteries but apparently the quality has gone way down. I need to find a good battery to fit in my 97 XJ and any advice would be appreciated. I would like to stick with the gel type and price is no issue as I want a quality battery not a cheap one.
Appreciate any suggestions.
Thanks,
JP
Old September 12th, 2017, 19:25
EMSJEEP's Avatar
EMSJEEP EMSJEEP is offline
Re: Battery opinions
Odyssey
Old September 12th, 2017, 19:35
Jeff-97XJ's Avatar
Which model did you get?
Did you have to make any modifications for it to fit and be secured?
Thanks,
JP
Originally Posted by EMSJEEP View Post
Odyssey
Old September 12th, 2017, 19:55
EMSJEEP's Avatar
Thanks,
JP
PC1500STM
It should drop right in. I just got it last week, so can't tell you much, but it's the other big brand out there. They have been around a while.
Old September 12th, 2017, 20:02
Heavyopp Heavyopp is offline
Deka intimidator -- AGM
I using them in 2 different vehicles -- no issues -- one of them is 6 years old and sees minimal use -- always turns the starter
I also have a few Sears diehard AGM -- they where rebadged Oddessy batteries for under $200 -- they also run great but Sears stopped offering them a couple years ago
Old September 12th, 2017, 21:29
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
I have a Wal-Mart battery I bought in 2008 for $95. I left the interior lights on a month or so ago. It faltered a little but started right up on the second try. I also have 4 aux lights, trailer lights, and everything works.
If I leave it sitting for more than a week, I put it on the 2A solar trickle charger. I've also taken it off to use on my trolling motor a couple times every summer. Just lucky I guess, but $200 is pretty pricey
1990 XJ - 4.0L AW4 It's white.
1988 MJ - 4.0L AW4 It's green.
Old September 12th, 2017, 23:09
Guess I forgot to mention those $200 batteries where group 65 -- Good batteries cost$$$
Old September 12th, 2017, 23:22
clydefrog's Avatar
clydefrog clydefrog is offline
Deka. Hands down. I have sold maybe 100 of them in the past 3 years and have never needed to warranty one. There that good.
I run a very high end European repair shop. This is the ONLY battery I would recommend. I did tons of research after I started looking for another supplier when Interstate got bought by Jonson Controls. Varta is another good brand but you cant get them here in the states.
Most all the other brands are made by Johnson Controls (including Interstate) which are garbage.
This is when Interstate sold to Walmart and Interstate was a good battery, they stopped in 2009. No surprise, I have seen the older interstates from this era go 10 years.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old September 13th, 2017, 08:40
denverd1's Avatar
denverd1 denverd1 is offline
Optimas have been made in Mexico for several years. quality is garbage.
clyde good info on Deka. thx
Old September 13th, 2017, 09:19
Supposedly the Sams Club AGM is a rebadged Deka Intimidator -- Made by East Penn
Not sure about the rest of the Sams club line but it may be worth looking into
Old September 13th, 2017, 09:43
blakews2217 blakews2217 is offline
Battery opinions
I've had good luck with the car quest house brand. Killed multiple times to dead. We're talking like 2-3 volts. After a jump and some 2 footing my 10 min drive home it was weak for a few days, but returned to good power. Had it for 6 years in other jeeps seeing the hot summers and the cold winters. Never let me down when it wasn't my fault. Went out at -12 to start her up. Had 10-40 oil in it and a stroker motor. I bit slow but did it.
Old September 15th, 2017, 12:29
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Odyssey
Diehard platinum is the same battery with a better warranty. A little bit cheaper too if I recall. Either way that's the route I went. Another plus for the DH, at least in my case is the availability of local Sears stores.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
SoCal Chapter VP
Old September 15th, 2017, 12:35
asymptonic asymptonic is offline
Unfortunately, I think Sears discontinued the Platinum.
Old September 15th, 2017, 13:31
Bent's Avatar
That'll leave me in a spot if I have a warranty claim.
SoCal Chapter VP
Old September 15th, 2017, 23:35
clydefrog's Avatar
Don't forget. Warranty claims are no good when your out in the middle of nowhere with a cheap battery.
OEM battery surgery, or how to salvage a dead OEM battery Ecomike OEM Tech Discussion 2 April 12th, 2016 14:42
AGM Battery - Failed Twice, bulging battery Markos OEM Tech Discussion 19 November 23rd, 2013 15:14
battery opinions AaronJXJ Modified Tech Discussion 3 March 12th, 2008 18:15
Whats killing my Battery ?? dual battery system MACH90XJ Tow Rigs and Trailers 3 July 27th, 2004 17:26
