Old September 6th, 2017, 04:23
Tapani Tapani is offline
New carpets, seat covers and color coding?
Hi all,
I am restoring the 1988 Cherokee Laredo which I bought years ago when living in San Antonio TX.
The engine bay is completely empty, all interior and dash removed. A few spots have required new metal - nothing major, though. Rust proofing has truly made a huge difference.
Now I am searching for a replacement carpet set. So far I've talked to Stockinteriors.com.
The exterior is "metallic navy", but I have no clue what the real color code is. Carpets are also blue, but a light shade. I don't have the build sheet for the car - and there's the badge in the engine bay infront of the drivers side A-pillar. In addition to the VIN it has the following codes:
J639481 12 0171173
17-7 47-C
116-X 139-LA
CEAL 17 2QW
Are any of these color / trim codes? What do they say :-)?
The front seat foam is shot on the drivers side and the seatscovers on both front seats. Are these still available?
Any and all help is appreciated,
Tapani
Finland
Old September 6th, 2017, 08:32
90xj06's Avatar
90xj06 90xj06 is offline
Re: New carpets, seat covers and color coding?
hmm i also have an 88 Laredo and i suppose it is a dark navy i always thought it was called dark Baltic metallic.
or Dark Baltic Metallic. Code (CE) interior is either charcoal, navy, cordovan, brownstone.
Im going to guess its Navy. but sun bleached. i removed my center console when doing work and the carpet was much darker.
Old September 7th, 2017, 09:53
Great, thanks for your answer. CE appears to be the paint code and is called what you said. http://paintref.com/cgi-bin/colorcod... k Baltic Blue
The interior is gray (charcoal?), but the carpets are definately light blue.
Well - I ordered a few samples - let's see how they turn out.
Br,
/T
Old September 13th, 2017, 05:44
90xj06's Avatar
let me know how this goes. im going to need new carpets soon.
Old September 13th, 2017, 09:02
Alaskan89XJ's Avatar
Alaskan89XJ Alaskan89XJ is offline
Greets from Alaska,
I am going to ramble a bit; (lol).
You moved an XJ from Texas to Finland.., right?
I am ignorant about how many XJ's are in your land.., but maybe you can find seats from a junked vehicle.., or another similar year XJ vehicle for sale, i.e., for it's parts?
Had to replace my seats that had a broken internal frame which I fixed somewhat, but found better seats from a junked vehicle. Lucky me. Can't recall what year when the seat frame bolting pattern changed, but someone might recall. If way more modern.., some fabricate iron adapter spacers to bolt to the floor, allowing older seat buckets to bolt somewheres into that.
You might have an upholstery shop in your area that could restore your seat(s) fabric with your choice. I would imagine they can 'splice', i.e; glue, and shape to restore the missing foam. Leather would be a nice cover. However consider obtaining full Sheep skin wool covers. Expensive, but quick, and most warm for our long winters. If you go that way, and you have a dog consider obtaining some kind of 'bitter apple' type spray from a pet store in order to dissuade any chewing.
Best wishes.
1989 Base RENIX XJ, 4.0,BA10/5,NP231,(200k+), no A/C, OME: 2" HD; coils, leafs, Nitro Sport shocks, T-Case spacer. KevinsOffRoad; steering box brace, HardKor Track Bar, stabilizer. JKS sway bar discos, (tossed out rear sway). Warn M8000 in ARB Kangaroo Bumper. OEM 15" steel wheels; 30X9.50 Dynapro muds, OEM 15" alloy wheels; 27" Blizzacks. Recycled oem seats. CIBIE/OSRAM head lights w/protective rock mesh guards. Replacement windshield, Rain-X wipers.
drivers seat and passenger seat covers 92 two door kayle666 SoCal For Sale 1 April 13th, 2012 12:29
Seat Savers seat covers DSBLAKE OEM Tech Discussion 0 April 4th, 2008 09:22
seat covers flexj For Sale: Private Party Only. XJ ITEMS ONLY 1 May 4th, 2005 21:51
color coding for ignition switch harness Micha OEM Tech Discussion 0 September 7th, 2004 11:50
