Old September 4th, 2017, 19:26
stonew1995 stonew1995 is offline
Jeep Cherokee XJ
What can I achieve with a 1.5" lift could I clear 31x10.50 15 with a fender cut and also can you upgrade to heavy duty tie rods other heavy duty suspension parts with a small lift just mild off road use really just driving on off-road paths and climbing here and there?
Old September 4th, 2017, 21:06
Green XJ Jeep Green XJ Jeep is online now
NAXJA Member 4950
Re: Jeep Cherokee XJ
With 1.5" you should probably stick with 235's
Old September 5th, 2017, 03:59
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
With 1.5" of lift, 30 x 9.5 will fit nicely, 31's would require trimming of plastic and probably sheet metal also. No need for heavy duty parts for mild off-roading. Some upgraded shocks would be a good idea.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old September 5th, 2017, 07:54
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
2" lift and 30x9.5's. No rubbing, fits great, drives great. Probably how it should have come from the factory.
Running the SFR 7075 aluminium replacement tie rod.
Available here
Jeep Cherokee & Grand Cherokee header/exhaust by Mopar Performance XJmatt85 SoCal For Sale 9 May 13th, 2017 21:31
My Jeep Cherokee build: 1997 Cherokee Sport workman13 Modified Tech Discussion 8 January 21st, 2015 07:51
F/S: 1996-down Jeep Cherokee/Comanche Parts (help fund an 11-year-old's Jeep project) 1x1_Speed_Craig MWC For Sale/Wanted Forum 16 April 26th, 2012 02:58
1994 Jeep Cherokee 4 x 4pre runner - $65001994 Jeep Cherokee 4X4 .4.0L mtr 5 speed ma Tom_T&Js_Offroad SoCal For Sale 7 August 18th, 2010 15:37
