Old September 2nd, 2017, 19:03
kippo1 kippo1 is offline
La v8 swap
Ok. I am getting ready to start buying stuff to do the swap over the winter.
For those of you that have done it what are some problems you ran into or things you would do different. I'm looking at a 6.0 swap. I have access to i think it's a 04 2500 4x4 with a 6.0.
I just don't want to buy something I should not have or not get something I need. I know I have seen photos of problems with hood clearance and I do want to keep a.c.
Old September 2nd, 2017, 20:17
Kittrell's Avatar
Kittrell Kittrell is offline
Re: La v8 swap
http://www.naxja.org/forum/showthread.php?t=1108551
http://www.naxja.org/forum/showthread.php?t=1007477
Old September 2nd, 2017, 21:20
Re: La v8 swap
I have made a lot of notes off those two threads.
Old September 2nd, 2017, 21:51
TRCM's Avatar
TRCM TRCM is offline
Re: La v8 swap
ok...LA V8 is a dodge small block....guessing that's not what ya meant if you are looking at a 6.0
Old September 2nd, 2017, 22:13
Kittrell's Avatar
Re: La v8 swap
A is right next to S on the keyboard.
Old September 2nd, 2017, 22:24
Re: La v8 swap
And my phone autocorrects ls to la. Sorry about that.
Old September 3rd, 2017, 09:31
TRCM's Avatar
Re: La v8 swap
yeah, I figured it out....just made me think for a second someone was gonna do an old style small block build.
kinda wish I still had my old 360...it'd have been a good one to swap in. Had some goodies in it, and based on track numbers/weight, it was ~ 450 hp.
Old September 3rd, 2017, 12:07
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Re: La v8 swap
Pretty much all of our LS swap threads have a ton of information about what we did and what we would change. I read the entire 5.3 swap thread on Pirate4x4 and multiple LS swap threads on here. There weren't many when I started my swap but since then there have been 3-4 successful swaps with build threads on
Old September 3rd, 2017, 23:31
Re: La v8 swap
I'm just a little confused. Some threads state the 6.0 truck manifold will not clear hood. Other says swap truck for car manifold and use access. Drive off corvette. Others say corvette accesorie drive will not clear frame rail. Some say it will. I haven't seen a specific one that mentions retaining the a.c.. unless I read passed it and just missed it.
Old September 3rd, 2017, 23:43
clydefrog's Avatar
clydefrog clydefrog is offline
Re: La v8 swap
Truck intake will not clear the hood, you are correct. Corvette intake will clear the hood but the stock accessories wont, which can be fixed with aftermarket products (see my sig). Check your local laws first to see what is allowed. I think your biggest challenge will be motor fitment. The heads and manifolds fill be a tough fit with the 6.0. The stock a/c should work (it did on my 5.3), stock Corvette p/s pump wont fit, it is too wide. Check out kwik LS brackets.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old September 4th, 2017, 07:43
TRCM's Avatar
Re: La v8 swap
Why would it be any harder to fit a 6.0 in over a 5.3 ??
They are the same block & heads, and I don't see the exhaust being bigger enough to make a difference.
Old September 4th, 2017, 21:33
Re: La v8 swap
Awesome thanks. Checking out your Sig now.
Stock a.c. as in stock jeep or stock 6.0 ac?
Old September 4th, 2017, 21:35
Re: La v8 swap
Oh and as far as local laws here for swaps there are none.
Old September 4th, 2017, 21:51
clydefrog's Avatar
Re: La v8 swap
I was under the impression that the 6.0 had a larger block. Since I barely have 1/2" in some places (with the 5.3) I didn't think a 6.0 would be an easy fit.
Stock 5.3. It powers my on board air system.
I also have a second compressor for a/c which is all custom, the only Jeep component is the evaporator.
Old September 5th, 2017, 14:21
TRCM's Avatar
Re: La v8 swap
I know they are different material, but I thought they were the same physical size, just different bore & stroke to give the different cid.
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 08:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
