Old August 31st, 2017, 20:08
Yzzerdd Yzzerdd is offline
Added LED reverse lights to the XJ-Impressed.
I didn't take any before pictures, as I was too excited to get these in; nevermind the fact that everybody here probably knows what the stockers look like. LED's on a vehicle CAN be a touchy subject, but I wanted to improve the visibility behind me without having spotlights or what-have-you hanging off the rear bumper. I did see a picture wherein someone flush-mounted two thin, rectangular LED assemblies in the lip-That would've been my next step, if this hadn't worked out so well.
These are DuraFlux 2500 Lumen light bulbs, 160W equivalent power. I'm not sure how much amperage they draw, but plan to check in the future. The difference is dramatic-Here's a shot of the vehicle with them on, the view as I back into a space, and with them off.
I'll post some more "professional" pictures soon, with measurements and such under more defined conditions. I'll also entertain requests, should anybody be looking for something more specific.
Jack
Old August 31st, 2017, 21:53
Re: Added LED reverse lights to the XJ-Impressed.
Here's a stock photo of the bulbs for reference- They arrived as shown, nice neat solder joints and professionally constructed. Not cheap Asian Pacific Rim garbage. I'm not intending to advertise for this company at all, but these bulbs are what convinced a skeptic and known tight-wad to spend $10.
J
Old September 1st, 2017, 09:38
Tbone289's Avatar
Tbone289 Tbone289 is offline
Can you give us a part # for those?
Old September 1st, 2017, 12:16
The eBay listing has "DF-3157" as the part number- eBay item 232334783400.
I am not affiliated with the seller of the above eBay item. A google search of "DuraFlux 3157" brings up other sources as well.
J
Old September 1st, 2017, 16:07
thegrayham thegrayham is offline
Did you have to do any ballast / capacitor, or were they simple plug and play? I wouldn't mind some additional back up lighting for night wheeling.
Old September 2nd, 2017, 06:10
They're plug and play, absolutely no modification necessary. Generally, you'll only need a resistor/etc if replacing turn signal bulbs or brake/turn(or hazard) combo bulbs.
J
Here's another shot:
Old September 2nd, 2017, 07:51
Anak's Avatar
Anak Anak is offline
Mostly Harmless
I am guessing, from the shape of the bases of those bulbs, that yours is a late model ('97+).
And those years at least have a big enough lens to get some light through it.
Old September 2nd, 2017, 12:31
iwannadie's Avatar
iwannadie iwannadie is offline
Not trying to hate but I am not a fan of all the recent hyper bright led lights. It sucks being on the receiving end of them. I known they are just back up lights but I had someone pulling out of a parking spot and the lights were pretty much eye level, I was seeing spots afterwards.
97 Country 4.0 auto 4x4(231) 31s
Old September 2nd, 2017, 13:15
You'd be right, 2000.
Iwannadie- I appreciate the input greatly. I was concerned as to the brightness of hr bulbs, I certainly wouldn't put in LED headlights- They are quite bright. Typically I'm just backing up into my garage at night, but when I'm out and about, I'll keep that consideration in mind.
J
Old September 5th, 2017, 06:32
Kentucky Jelly Kentucky Jelly is offline
J
Brightness isnt the issue for headlights. It is having a proper cut off, or beam. Nice led headlights will not blind oncoming traffic. There is nothing wrong with led headlights, and they are some of the best money spent on these old jeeps imo.
Old September 5th, 2017, 12:39
iwannadie's Avatar
Correct. It is the people sticking improper light sources in housing that are not designed for them. The people with HIDs in stock halogen housings that blind everyone and aren't even throwing useful light down the road for themselves but wow they sure "look" bright and "cool". /rant
Old September 5th, 2017, 20:23
The issue I've run into is finding quality bulbs that will give the proper beam pattern. I've read many threads here about it, probably would go with the trucklites. Right now I have the brightest standard bulbs that Napa had available, Wagner brand. They're OK, but the Sylvania UltraStars in my wife's car are much brighter.
J
Edit: Note, I have not yet upgraded my OEM headlight wiring harness. I'm sure to get through the winter on the bulbs I have now AS LONG as I do the wiring this fall. I don't want to put $360 of headlights on the front of the Jeep, only to have them knocked out in an icy parking lot.
Old September 6th, 2017, 10:58
fallacist fallacist is offline
J
When you get your harness, don't skimp and get that crappy putco harness. Spend money once and do it right the first time and get the ARB or another higher end harness.
Old September 6th, 2017, 22:50
notamos's Avatar
notamos notamos is offline
Susquehanna Motorsports...
Brake lights and reverse lights on at the same time madmax OEM Tech Discussion 6 September 20th, 2016 21:35
Looking for automatic trans reverse light color to wire in the reverse lights Atm3535 OEM Tech Discussion 0 January 19th, 2016 05:25
need reverse lights for inspection..How can I bypass nss for lights to work JSwamper OEM Tech Discussion 5 September 15th, 2011 17:06
No reverse lights or brake lights or turn signals... TheHighHeat OEM Tech Discussion 6 October 5th, 2008 16:13
added some lights today diabloxj Modified Tech Discussion 23 March 6th, 2005 19:20
