Old August 31st, 2017, 09:27
LJRockstar's Avatar
LJRockstar LJRockstar is offline
Anyone running these?
I like the idea alot.... I just fear its gonna be all squeaky and rattley.
Anyone have any experience with them or this company?
Leaf spring sliders.
Thanks!
Old August 31st, 2017, 10:23
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
Re: Anyone running these?
I don't have any personal experience with them, but they look like a clever design and per post #29 in this thread Creeper2012 highly recommends them:
http://www.naxja.org/forum/showthread.php?t=1125743&highlight=Liquid+iron+sli der
"Nothing is so invertebrate in nature as the worm of a lie that has been stepped on by the iron boot of truth." (Raezer v. Raezer, 428 Pa. 163, 166 (1968) (opinion by Justice Musmano).)
Old August 31st, 2017, 11:21
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Not so shameless plug... Leaf sliders work great for travel (pre-runner/go fast stuff). Our Comp Shackles work great for maximizing leaf spring flex.
http://www.boostwerksengineering.com...les-_p_24.html
20140818_144153 by Bryson Whissen, on Flickr
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old August 31st, 2017, 11:29
trippled trippled is online now
Pretty sure that's timmay on PBB. never heard anything bad about those, but never run. Supposed to help with some of the hinging inherent in a shackle. Keep in mind depending on your setup it may change lift and pinion angle.
Old August 31st, 2017, 12:25
PhotoJared's Avatar
PhotoJared PhotoJared is offline
I really liked them but they wouldn't work with my application. For some reason they or my leaf springs weren't parallel with each other so the leafs rubbed on the boxes.
Build quality was great and I wish i could use them but I cant.
Old August 31st, 2017, 13:39
LJRockstar's Avatar
Those are interesting as well, what I'm REALLY interested in of yours is that winch mount/steering brace that hides behind the factory bumper! Any updates on that?
Old August 31st, 2017, 14:24
Mach2nh Mach2nh is offline
Not really showing how much rear droop. Lift the front so it stuffs a rear and unloads ther other.
Old August 31st, 2017, 16:46
jonesinxj jonesinxj is offline
off subject... but what fender trim are you running?
Old September 1st, 2017, 03:54
themauler's Avatar
themauler themauler is offline
If you do a lot of rock crawling beware they apparently bend up easily if you start rubbing them on the rocks. Otherwise they have always interested me.
Nick Maul,
Just want to build something that won't break on the trail
Old September 1st, 2017, 06:53
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I looked at sliders for the KOH XJ.
Guys who have tried them coming out of competition rock crawling said they don't allow the leaf to twist enough and cause a lot of binding, and then fail.
Enough people were adamant enough that we even bother testing them.
Old September 1st, 2017, 10:42
VAhasnoWAVES VAhasnoWAVES is offline
boostwerks stuff seems to work well, and have been very tough... pair them with shackle relocation brackets.
Old September 1st, 2017, 10:44
cal's Avatar
cal cal is offline
I think I'm going to have to check out the boostwerks shackles.
Old September 1st, 2017, 12:08
jeeptec's Avatar
jeeptec jeeptec is offline
There shackles look pretty cool.
Old September 1st, 2017, 19:19
ehall's Avatar
ehall ehall is offline
I've seen a few guys here in the NE run the LII sliders, they get good reviews. Biggest downside is have to run a taller leaf with more arch which doesn't unload as much, and shackles on a flat leaf will unload a lot more. On the other hand low-hanging shackles catch on a lot of stuff, especially in reverse.
my '91 beater rebuild
Old September 2nd, 2017, 04:33
LJRockstar's Avatar
Thanks everyone for your input. The general consensus is, that these are probably not for me. I really like when people think out side of the box and these certainly fit that bill, but my rig (at least for the foreseeable future) is a DD that will see the occasional trip to Rausch Creek or maybe some logging roads in the New England area. Ill probably go with some shackle relocation brackets and upgraded shackles (Boostwerks, I'll be looking your way, hopefully the winch mount will be ready by the time I'm ready to pull the trigger on some of this stuff...) The main thing with this build is to not hinder the highway performance too much. I'm totally ok with some of the quirks that come with driving a lifted truck, but a few of my past builds got beyond a certain threshold and became just too unwieldy for street use. I want to keep on the Overland side of things more than the smashed up rock crawler end of the spectrum.
Running HOT PRYAPSM Arizona Chapter 18 July 5th, 2011 10:29
Running down running hot issue ParadiseXJ OEM Tech Discussion 16 October 5th, 2009 10:43
Is anybody running this... EazyXJWJ Modified Tech Discussion 0 December 31st, 2008 08:36
Will not stay running (not normal running issue) bigbadwolf54 OEM Tech Discussion 5 August 26th, 2007 13:07
