Old August 31st, 2017, 04:15
Evan03 Evan03 is offline
What is different on newer than 98 grand cherokee breaks.
Looking to do the swap to disc everything at the junk yard im finding is newer than 98
Old August 31st, 2017, 07:41
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: What is different on newer than 98 grand cherokee breaks.
Won't work for you. I mean you could probably modify it to work, but you'd have to modify A LOT.
The brakes you want are from a ford explorer. Anything solid axle with disc brakes.
Basically the same as the ZJ, but more common and a better finished product.
Old August 31st, 2017, 09:46
RCP Phx RCP Phx is offline
What rear axle do you have?
Old August 31st, 2017, 18:01
8.25.
But i appeares zj disc flanges bolt on dana 35 8.25 and 44.
I am not afraid of modding. Thought about welding brackets on and running chevy half ton or anything with 5x4.5 rotors
Just have seen no reason newer than 98 zj brakes cant work.
When did 5" lug pattern happen
Old August 31st, 2017, 18:54
deesiexj's Avatar
deesiexj deesiexj is offline
Evan03,
You might also look at KJ Liberties. I believe those were all equipped with 8.25 rear ends with disc brakes.
Check this out: http://www.naxja.org/forum/showthread.php?t=1116439
Old August 31st, 2017, 20:37
Yep, the KJ brakes fit the 8.25" with no mods!
http://naxja.org/forum/showthread.php?t=1134797
Old September 1st, 2017, 07:37
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Pretty much all zj brakes will work as well as liberty brakes. I think liberty will be easier because you dont have to enlarge the centerhole as much.
99 was the start of the wj's and the 5x5 bolt pattern. You can use wj parts also but you will have to redrill your rotors. It might be possible to use zj rotors on the wj disc setup but i am not possitive.
Old September 1st, 2017, 08:46
ZJ rotors will not work with WJ calipers! There is absolutely nothing to modify with KJ backing plates.
Old September 2nd, 2017, 05:39
cruiser54's Avatar
cruiser54 cruiser54 is offline
Even with ZJ parts, the hole can be enlarged very easily. You SAND it......
Old September 3rd, 2017, 13:06
sinat01's Avatar
sinat01 sinat01 is offline
Im gearing up to do the KJ swap. figured itd be the simplest. done have to grind anything. just longer mounting bolts, and D30 front wheel studs and your in business. Do have to mess with the hardlines a bit, but doesn't cost a lot.
2012 or newer grand cherokee question poomero NorthWest Chapter 2 January 19th, 2016 10:04
WTT; 2000 cherokee for 99 or newer grand cherokee kdub41 SoCal For Sale 39 May 20th, 2010 16:12
XJ or upgrade to newer Grand Cherokee? raypla OEM Tech Discussion 21 January 30th, 2006 06:11
Cherokee seats, Grand cherokee rear seats, and Grand Cherokee seat rails sacto_patrol For Sale: Private Party Only. XJ ITEMS ONLY 8 January 3rd, 2005 22:05
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
