Old August 30th, 2017, 11:46
97jeepxj1 97jeepxj1 is offline
Coil spring rubbing bump stop mount.
I nave new re3.5" coil springs, longer fixed rough country lower control arms, and a re adjustable track bar (it is centered) all newly installed. My passenger side coil is rubbing pretty bad on the bumpstop mount. I have noticed the slots for adjustment in the frame side lower control arm mount and by looking at the slots the passenger side sits all the way back in that slot while the driver side is about 1/2-3/4 of the way forward in the slot. Could this be the possible cause and if so can I just loosen the bolts of on the back side of the bracket and the lower control arm and adjust it out to correct the rubbing?
This is also still present after having a alignment done 2 shops have told me they don't know whats going with it.
Old August 30th, 2017, 16:22
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Coil spring rubbing bump stop mount.
1) Pictures ?
2) Find a real Frame and Alignment shop with some gray haired Techs. Retail tire stores that also sell alignments are helpless and clueless.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old August 30th, 2017, 18:51
I'm at work but I'll try to get some.
Old August 30th, 2017, 20:05
RCP Phx RCP Phx is offline
You should have a adjusting shoe in there but if your vehicle is in full alignment you might have a bent frame.
Old August 30th, 2017, 22:41
Yeah those are what I was talking adjusting. Doesn't look like either sides has any shims but one is definitely set back farather then the other whenight looking at slot in the bracket where the control arm passes through
Old August 30th, 2017, 22:46
Is photo bucket still not working to use for images?
Old August 31st, 2017, 09:38
Only if you pay for it!
Old August 31st, 2017, 11:31
Driver
Passenger
Old September 29th, 2017, 10:09
WyoCherokee's Avatar
WyoCherokee WyoCherokee is offline
Find those shims at a junkyard and center it up. the side that is off, is a good 3/4 to an inch to far back. The drivers side is maybe a half inch to far back. Make sure those control arms have matching part numbers/ lengths.
Old September 30th, 2017, 07:20
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
While you're messing around in the area you may want to straighten out you brake hard line as to lower the mounting point of the rubber brake hose. Bend the steel line gently, redrill and bolt the mounting plate down and slightly forward of where they are now. This will prevent the hoses acting as limiting straps.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
Old September 30th, 2017, 07:54
Jeep Driver Jeep Driver is offline
Your frame is bent.
Screw the shims. Zero out and make up with adjustable uppers and lowers.
Pull your measurements off the rear axle, square it up.
Old September 30th, 2017, 09:00
Tim_MN's Avatar
Shimming isn't going to help if the control arms are too short, or if the "frame" or the frame side control arm mounting point is bent.
You need longer control arms to cure the coil spring rub, you should buy adjustable lower control arms. Depending on the amount of lift you have you may want control arm drop brackets. Drop brackets will move the axle forward slightly, but will not compensate for what looks like a bent frame/mounting point. If the frame is actually bent, you should buy adjustable lower control arms. Adjustable upper control arms may be optional, depending on the amount of lift you have and the pinion angle required.
Old November 2nd, 2017, 15:10
Treleaven Treleaven is offline
I am in the same boat. longer fixed control arms that are for the lift. My shims look like they are not set properly.
Did you ever find a fix?
Rear U-Bolt Spring Plate & Bump Stop Mount WebDog Vendor Advertisements 1 September 6th, 2013 13:02
Motor mount for bump stop? hollyxj OEM Tech Discussion 12 April 20th, 2008 19:37
Front coil springs? Bump Stop boomer1 OEM Tech Discussion 14 July 29th, 2007 17:07
DPG Adj. Bump Stop Spring plates mmmkay325 Wanted: Private Party Only 1 August 8th, 2006 11:04
Bump Stop Removal for Coil Spacers? Whiskey Jack Modified Tech Discussion 8 September 12th, 2003 18:57
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
